210
Android Q Developer Preview 3 for OnePlus 6 and 6T
  1. drl431
    Marshmallow Aug 17, 2019
    drl431 , Aug 17, 2019 :
    This is a developer preview, its not even open beta yet. As this DP3 is a month old, the system will not allow you to install it if your current OOS is newer. You could use the rollback package in the first post to make your current OOS version older, then install DP3. But read the first post carefully and remember all data will be wiped.
    ironass likes this.
  2. VaguelyWoo
    Gingerbread Aug 17, 2019
    VaguelyWoo , Aug 17, 2019 :
    Oneplus should implement message pinning or something in that way so people don't have to ask the same question so many times
  3. James S
    Eclair Aug 17, 2019
    James S , Aug 17, 2019 :
    I just reinstalled preview 3 for the third time, and previously it was super laggy and constantly crashed, but this time it seems to work perfectly on my 6T, if your having the same problems where it was super laggy and constantly crashing make sure you aren't using any icon packs and make sure dark mode is turned off these are two things I've found to cause most of the problems, I don't use either if these and I can finally use android Q as a daily driver with no crashes.
    I'm using the new gestures also
    1salty likes this.
  4. James S
    Eclair Aug 17, 2019
    Xcutioner likes this.
  5. Aamerkhayat
    Cupcake Aug 17, 2019
    Aamerkhayat , Aug 17, 2019 :
    I'm on Open beta Pie, will i get OTA if open beta for Q is released or i have to locally upgarde ? if any one having idea about that
  6. 1salty
    Froyo Aug 17, 2019
    1salty , Aug 17, 2019 :
    who is your sim provider?
  7. amirhussaini93
    Ice Cream Sandwich Aug 17, 2019
    amirhussaini93 , Aug 17, 2019 :
    Of course OB Pie will get OTA OB Q because same channel, Open Beta or you also can upgrade via local upgrade (locked bootloader) or via TWRP (Unlocked bootloader). [e]1f609[/e]
  8. Aamerkhayat
    Thanks any news date time or something about Android Q next beta for Op6[e]1f60a[/e]
  9. anaskottayippm
  10. VaguelyWoo
    Read posts above, sir
    ironass likes this.
  11. amirhussaini93
  12. VaguelyWoo
  13. amirhussaini93
    VaguelyWoo likes this.
  14. D1564135424468
    D1564135424468 , Aug 17, 2019 :
    hallo all
    after install android Q DP3 my banking application error, notification appear from app "please insert sim card" any solution??
  15. Artemus.
    Nougat Aug 17, 2019
    Artemus. , Aug 17, 2019 :
    Probably should return to Pie.
  16. ngydat
    KitKat Aug 18, 2019
    ngydat , Aug 18, 2019 :
    Not such a good idea to install a developer preview knowing you use a banking app. Go back to the stable version of OxygenOS. Next time, consider all those things before rushing to a version of an OS that isn't suitable for a daily usage
  17. MS929
    Cupcake Aug 18, 2019
    MS929 , Aug 18, 2019 :
    Okay, I have been on and off Android pie and Android q for about 2 weeks. I'm currently on pie but I'm conflicted about switching back to Q. Mainly for two reasons: Sometimes when I unlock the phone the frames go to like 10 until I put it to sleep then unlock it again. (This happens about 6-8 times a day). And the other reason is the spontaneous app crashes of: YouTube, Netflix, and Instagram. I know that this is not the open beta and that this is meant for developers only, but I still would like to have a couple of people's opinion on what I should do next until the open beta for Q is released for the OP6.
  18. 1salty
    Froyo Aug 18, 2019
    1salty , Aug 18, 2019 :
    MS929
    stick with stable OS if having phone available when you need it is important to you. Some here use oneplus 6t as their spare, and they can afford to use the bleeding edge Q...
    I want to run Q, but I can only use phone in WiFi, and it won't work for me, so I went back to stable.
    preview 2 ran ok for me, but just display resolution just didn't render right scale for me. may go back to Version 2
  19. PlagueDoctor
    Donut Aug 18, 2019
  20. ironass
    Lollipop Aug 18, 2019
    ironass , Aug 18, 2019 :
    Read back through this thread as your issue has been answered countless times.
    You may also learn that OnePlus has abandoned this project for the 6 series.
    Artemus. likes this.
