205
Android Q Developer Preview 3 for OnePlus 6 and 6T
  1. PlagueDoctor
    Cupcake Aug 18, 2019
    PlagueDoctor , Aug 18, 2019 :
    no time for back read. thanks by the way.
  2. James S
    Eclair Aug 18, 2019
  3. Suroorzain
  4. ironass
    KitKat Aug 18, 2019
    ironass , Aug 18, 2019 :
    Read 3 posts before yours.
    Maverick2.0 likes this.
  5. gigeaky
    gigeaky , Aug 18, 2019 :
    Maybe this has been asked before but can't seem to find a solution for it, how do you get the battery stats to show? Because on mine it just says that it's not available.
    Cheers
  6. VaguelyWoo
    Froyo Aug 18, 2019
    VaguelyWoo , Aug 18, 2019 :
    if your on dp3, its just a bug where it doesn't work. No workaround or anything as for as I know. just wait for the next build.
    gigeaky likes this.
  7. VaguelyWoo
    Froyo Aug 18, 2019
    gigeaky likes this.
  8. Senthilkumarna
    Froyo Aug 18, 2019
    Senthilkumarna , Aug 18, 2019 :
    I can't able to reduce or decrease volume while playing media..is there available any solution for fixing this issue or not?
  9. amirhussaini93
    Ice Cream Sandwich Aug 18, 2019
    amirhussaini93 , Aug 18, 2019 :
    You can read previous page, already discuss about this.
    Enter Recovery Mode, clear cache and reboot.
    Actually, reboot will fix and it will come again.
    Unless, after you install Q DP3, and do format data. That issue will gone. I used few week, audio issue is bye bye. [e]1f604[/e]
  10. Senthilkumarna
    Froyo Aug 18, 2019
    thanks for your reply, I will try and reply
  11. Senthilkumarna
    Froyo Aug 18, 2019
    it's working now.
    is it working horizon light?
  12. amirhussaini93
    Idk mate. Is that function is for 7 Pro?
    Ignore feature like Fingerprint in-screen animation and that Horizon light because that is not for OP6, only fingerprints in-screen for 6T and above. [e]1f602[/e]
  13. Sun90
    Starting Point Expert Aug 18, 2019
    Sun90 , Aug 18, 2019 :
    Are you sure .
    ironass likes this.
  14. Senthilkumarna
    Froyo Aug 18, 2019
    mine for OnePlus 6t
  15. ironass
    KitKat Aug 18, 2019
    Add... "seemingly", abandoned. ;)
    It has now been 17 days since the release of DP4 on the OnePlus 7 series and still no release for the 6 series.
  16. G_deepak_Kumar_in
    Eclair Aug 18, 2019
  17. B1540645859558
    Donut Aug 18, 2019
  18. drl431
    Lollipop Aug 18, 2019
    drl431 , Aug 18, 2019 :
    If you have to ask, then you should not be installing a developer preview...
  19. amirhussaini93
    Poor Manu create thread, people not read it. [e]1f614[/e]
    Vaibhav_sinha, ade0410 and 1salty like this.
  20. 1salty
    Froyo Aug 18, 2019
    1salty , Aug 18, 2019 :
    amirhussaini93
    reading has always been challenging act for some.... may be Manu should freeze 1st post, and it should show up on every page...
    amirhussaini93, Kytharsis and ironass like this.
