210
Android Q Developer Preview 3 for OnePlus 6 and 6T
  1. 1salty
    Froyo Sep 14, 2019
    1salty , Sep 14, 2019 :
    you have to format your data. there is a version of gapps, and it works. I am using it on my OnePlus right now.
  2. amirhussaini93
    Ice Cream Sandwich Sep 14, 2019
    amirhussaini93 , Sep 14, 2019 :
    Yes, similar installation like AOSiP and i used alternative GApps here and works great.
    https://drive.google.com/open?id=1hoPX-cvvq4uKxBTo4TLHNC29iI-3p3sE
    Idk i use Android 10 OpenGApps Test bring back to TWRP.
    Btw, if someone looking GCam, use this one, works great. (dont forget to apply xml 2x)
    https://drive.google.com/open?id=1wan2iT_xbM0zFsgZn03YMsvrQ4uhONgP
    XML file
    https://drive.google.com/open?id=1am14HFhu5pJgUtZDUyobFfaIlRPMLUv2
    Fun to play it, but i back to OB25 and wait OBQ from OnePlus. ;)
    * Sorry for OT, now back to OOS Q topic. :p
  3. N1535126586141
    Cupcake Sep 14, 2019
    N1535126586141 , Sep 14, 2019 :
    Hi, I have a problem updating my smartphone to Android 10, giving the following error when selecting the update: "system update installation failed". Someone help me? 1568500392320.jpg
  4. 1salty
    Froyo Sep 15, 2019
    1salty , Sep 15, 2019 :
    please read the first post by op. it is not that difficult. you have to downgrade depends on which version you are running, and then run dp3 as local installation after you download and copy to the sdcard .
  5. Y1550400572257
    Cupcake Sep 17, 2019
  6. Piyush_25
    Cupcake Sep 20, 2019
  7. Artemus.
    Nougat Sep 20, 2019
    Artemus. , Sep 20, 2019 :
    The DP program is essentially over. Wait for the next Open Beta to release later this month.
    drl431 and ironass like this.
  8. Piyush_25
    Piyush_25 , Sep 20, 2019 :
    so I cannot install android Q on my phone? because next open beta is releasing?
  9. Artemus.
    Nougat Sep 20, 2019
    You can install Android Q/10... just not this version as this is a developer preview build and is less-than-ideal for daily driver usage. The next Open Beta version is said to be based on Android 10 and will be more complete.
  10. Piyush_25
    ok thanks bro
    Artemus. likes this.
  11. prabhatspatil@gm
    Froyo Sep 20, 2019
  12. K1546869398185
    Donut Sep 23, 2019
  13. B1545399860217
    Cupcake Sep 23, 2019
  14. K1546869398185
    Donut Sep 23, 2019
    B1545399860217 likes this.
  15. PsychoFox
    Donut Sep 23, 2019
  16. B1545399860217
    Cupcake Sep 24, 2019
    B1545399860217 , Sep 24, 2019 :
    He runs all OnePlus beta and stable threads on xda so I think he works for them but I could be wrong
  17. unrooted
    Cupcake Sep 25, 2019
  18. Artemus.
    Nougat Sep 25, 2019
    unrooted likes this.
  19. milindkarpe
    Cupcake Sep 30, 2019
    milindkarpe , Sep 30, 2019 :
    Those of who wants to try Android 10 DP3 update. First rollback to the older version of stable version and then install DP3 update.
    Cheers !!
  20. DenyDarko
    Honeycomb Sep 30, 2019
    DenyDarko , via OnePlus 6 , Sep 30, 2019 :
    Guys, moving from DP 3 to the very soon expected OB based on 10 it'll probably (definitely?) require a wipe.
    It doesn't deserve it.
    You'll live with Android 9 for a few days.
