182
Android Q Developer Preview 3 for OnePlus 6 and 6T
  1. Pankkajarora Froyo Jul 19, 2019
    Pankkajarora, Jul 19, 2019 :
    finally, a build which can be a daily driver.
    some observations on op6
    1. camera application is unstable, especially front camera you can clearly see the display changing Colors. may be due to selected display settings.
    2. you get to see some white lines on bottom corners
    3. phone has become really slow but still manageable.
    4. new gesture navigation are super cool, you'll take some time to be habitual of it.
    5. banking applications not tested yet.
    6. first time account setup with dual authentication enabled take some time.
    7. second volte sim doesn't get activated by default, you've to enable the data for first time to make it work.
    8. phone unlocking is issue because of ambient display setting.
    enjoy the build and have fun.
  2. Apoorvtrikha Cupcake Jul 19, 2019
  3. MMuralidhar Gingerbread Jul 19, 2019
    MMuralidhar, Jul 19, 2019 :
    2nd point they are part of gusters
    will open Google Assistant
    Pankkajarora likes this.
  4. Maverick2.0 Jelly Bean Jul 19, 2019
    Maverick2.0, Jul 19, 2019 :
    Still not daily driver material. I would advice against installing it unless one knows what one is getting into.
  5. Pankkajarora Froyo Jul 19, 2019
    yeah, depends on individual.
    for me I can live with this build because I've installed the 1st DP preview as well and gave a skip to the 2nd build.
  6. X1541639982759 Cupcake Jul 19, 2019
    X1541639982759, Jul 19, 2019 :
    Did you get this finally installed? It's fairly easy. Download the beta 6T version. Once the file has successfully downloaded, follow these quick and easy steps. ( Remember to do and force Google backup before you try and install the beta software) This will be a new install and will wipe everything clean ok.
    So once you've backed up, you can now go to downloads. Tap the beta file and copy it to the main internal storage drive. Once the file has moved go to settings, system updates and click on the gear/cog upper right corner. Select local upgrade and the beta software will install.
    After the beta file has installed, reboot. You will start a fresh likes it's a new phone. Go through the normal, setup steps.
    Good luck.
  7. Maverick2.0 Jelly Bean Jul 19, 2019
    If you managed with the first DP, then certainly for you. But not for the majority of users, I am afraid.
  8. Pankkajarora Froyo Jul 19, 2019
    true and it's clearly written developer preview
  9. X1541639982759 Cupcake Jul 19, 2019
    Yes it will.
    Yash chawla likes this.
  10. X1541639982759 Cupcake Jul 19, 2019
    I've been using the beta software for about seven hours and so far OK. Fairly stable, a little slow generally but that's to be expected. Boot up takes about 30 -45 seconds + but who cares.
    Batter life not so good but again, install Beta software, you'd expect quite a few issues. It's quite stable.
    I will use it over the next few days and the weekend and see how it goes.
  11. smr31796 Donut Jul 19, 2019
    smr31796, Jul 19, 2019 :
    I am getting system UI keeps stopping during setup. Tried factory reset and wipe everything nothing helped. I am not able to go past PIN setup after that it just goes blank. I need help with this can somebody help.
    sankar.kaza likes this.
  12. X1541639982759 Cupcake Jul 19, 2019
    Wow, that is very strange. I'm sorry , I don't have any ideas. Hopefully, someone else can help you out!
  13. MahanthSiddu01 Cupcake Jul 19, 2019
    MahanthSiddu01, Jul 19, 2019 :
    which one should be download now ....
  14. Murali_krish_na Cupcake Jul 19, 2019
  15. X1541639982759 Cupcake Jul 19, 2019
    Yes, one person on here claims under the developer tab, you can enable game drivers preferences and switch on all apps. I tried and nothing changed. Even after a restart.
  16. smr31796 Donut Jul 19, 2019
    Okay I found the reason for my system UI keeps stopping issue. I think it is because of network. Can anyone using AT&t with OnePlus 6T confirm if they have any similar issues or have issues with network reception?
    1salty likes this.
  17. Aasim K Froyo Jul 19, 2019
    Aasim K, Jul 19, 2019 :
    That was to increase performance,if im not wrong.Not for Volume.Check above post for Volume issue,that method works.
  18. smr31796 Donut Jul 19, 2019
    Can anyone confirm if they have network reception with OnePlus 6T working with AT&T. I am facing system keeps stopping and no reception with the network. Soon as i remove the sim card phone is back to life with no issues.
  19. pastalex42 Eclair Jul 19, 2019
    pastalex42, Jul 19, 2019 :
    I have no issues, At&T 6T
  20. pastalex42 Eclair Jul 19, 2019
    On 6T same thing. can't adjust it at all
