201
Android Q Developer Preview 3 for OnePlus 6 and 6T
  1. G_Gokula_Krishnan
    Cupcake Jul 20, 2019
    G_Gokula_Krishnan , Jul 20, 2019 :
    Can you please share ur experience and procedure??? Cuz i cant really do it again and again!
  2. amirhussaini93
    Ice Cream Sandwich Jul 20, 2019
    amirhussaini93 , Jul 20, 2019 :
    Check out rollback file on first page. Procedure same like you update to Q DP3.
    Then, update to latest OOS version, then install again Q DP3.
    Like i share before, i flash Q DP3 over OB22, then after flash Magisk, that audio issue exist. Then i use msmdownloadtools to back to normal, flash again over 9.0.7,then after flash Magisk still exist that issue.
    Then i run again that program, not unlock bootloader, local upgrade 9.0.7 (i use full zip because already have that zip), then local upgrade this Q DP3. No audio issue anymore. (so far right now)
  3. JuAnCaStRoP
    Gingerbread Jul 20, 2019
    JuAnCaStRoP , Jul 20, 2019 :
    Can someone please help me
    Hi, I tried to install the developer version and it did everything like it was supposed and then when it rebooted it gave me a yellow message that said software and hardware do not match. Or something like that. I am have a t-mobile international version installed. What do I do.
  4. Dgafking0480
    Dgafking0480 , Jul 20, 2019 :
    I'm trying to figure out the same thing too
  5. JuAnCaStRoP
    I have read that is stable enough and I want to give it a go.
  6. Dgafking0480
    same here, gotta figure out the mismatch thing first thought. I had the same issue you did
    JuAnCaStRoP likes this.
  7. Aryaraj Singh
    Donut Jul 20, 2019
    Aryaraj Singh , Jul 20, 2019 :
    Isn't that obvious?
  8. JuAnCaStRoP
    It is weird cause the first time I done it I was on the beta and the second time it was the normal.
  9. Maazperwez
    Honeycomb Jul 20, 2019
    Maazperwez , Jul 20, 2019 :
    is everyone's device play store certified? can anyone check and confirm me? go to play store settings then scroll down and there should be device certification what does it say
  10. W1546762019111
    Froyo Jul 20, 2019
  11. JuAnCaStRoP
  12. amirhussaini93
  13. saurabh2020
    saurabh2020 , Jul 20, 2019 :
    I have no sound from the speakers of the phone. Bluetooth earphones works OK but max volume is very low. Is anyone facing no sound issue from phone speaker, tried all music apps, YouTube, Netflix etc.
    I have Oneplus 6
  14. _Isiah_Sweet_
    _Isiah_Sweet_ , Jul 20, 2019 :
    Just got my first oneplus yesterday. Hell of a deal for a 6t. Im definitely not new to android and developer builds. Spent way too much time and money on an hd2 back in the day. but i digress. So far the build has been very stable for me.
    Notes so far:
    Its very smooth, no hiccups or issues yet
    Fingerprint scanner is actually faster and working better for me (could just be mine?)
    Noticed the google play store was not certified but ive had no issues because of it yet.
    The build is pretty good in my opinion and hopefully the final release will be this smooth.
  15. sunit6k
    Donut Jul 20, 2019
    sunit6k , Jul 20, 2019 :
    Q Dp3 on OP6 after 2 full days of use
    1. Stable enough for me to be used as daily driver.
    2. No weird lags or app crashes except for the Twitter app which crashes at least twice a day.
    3. No audio issues after reboot.
    4. Launcher crashes only if any other icon pack except for OnePlus (the first one in Icon Pack) is used. Otherwise launcher is stable without any glitches.
    5. New navigation gestures work great without any lags.
    6. Performance overall has been great for me.
    7. All banking apps work fine.
    8. Google pay works.
    9. Battery life is above average. Can easily get through an entire day with 20-30% remaining.
    10. Battery bug: screen usage since last charge always at 0 mins.
    11. Fingerprint scanner, Face Unlock, Bluetooth, WiFi, Mobile data, NFC, Volte all working.
    12. Smart display working.
    13. Screen calibration appears to be broken.
    14. Dark theme works great. Also, force dark option in developer options works.
    15. Dash charging working as well.
    Updated from OB22 to DP3.
    Maazperwez likes this.
  16. Maazperwez
    netflix?? is shown on playstore is the device certified?
  17. sunit6k
    Donut Jul 20, 2019
    Yes, it's shown on play store. As a matter of fact I have it installed on my phone and don't have any issues with it yet.
  18. Maverick2.0
    KitKat Jul 20, 2019
    Maverick2.0 , Jul 20, 2019 :
    Thank you. Good review. May be I will give it a shot tomorrow...
    By the way, is Horizon Light available for the 6?
  19. sunit6k
    Donut Jul 20, 2019
    I can see it under settings->customization but it doesn't work no matter what I did.
  20. Maverick2.0
    KitKat Jul 20, 2019
    Ok. Thank you. At least it's there. That means it will be enabled at some point.
