201
Android Q Developer Preview 3 for OnePlus 6 and 6T
  1. sunit6k
    Donut Jul 20, 2019
    sunit6k , Jul 20, 2019 :
    No cast related issues here.
  2. RodiNet76
    Froyo Jul 20, 2019
    RodiNet76 , Jul 20, 2019 :
    Installed and very usable. Do not like the new gestures for back, but I will get used to it.
    Most of the apps works well, even if it advises that we should update, blablabla...
  3. JuAnCaStRoP
    Gingerbread Jul 20, 2019
    JuAnCaStRoP , Jul 20, 2019 :
    What did you do because mine did not even get that far.
  4. gaurabchak
    Cupcake Jul 20, 2019
  5. rafflax
    rafflax , Jul 20, 2019 :
    Do we know when google will roll it out? Nop. So how can 1plus know,.?
  6. vijaykmr603
    Cupcake Jul 21, 2019
    vijaykmr603 , Jul 21, 2019 :
    I want go back from Android Q to old version, I downloaded downgrade but it wasn't showing in root directory
  7. Dgafking0480
    Ice Cream Sandwich Jul 21, 2019
    Dgafking0480 , Jul 21, 2019 :
    does anyone believe in searching the post before they post? geeze I've seen the same post from multiple people a lot
    Vansh99 likes this.
  8. vijaykmr603
  9. vijaykmr603
  10. laikexpert
    Froyo Jul 21, 2019
    laikexpert , Jul 21, 2019 :
    for OnePlus 6
    All works OK.
    (And with Nova Launcher Pro.)
    Without any problems.
    PS.
    Thanks OnePlus
    I dont have any problems.
  11. uae727
    Froyo Jul 21, 2019
    uae727 , Jul 21, 2019 :
    I'm facing issues with speakers its not working I can't hear a thing does any one had this issue ??
  12. jaygatsby9909
    Honeycomb Jul 21, 2019
    jaygatsby9909 , Jul 21, 2019 :
    Remove .jar from the file.
    Maverick2.0 likes this.
  13. MMuralidhar
    Gingerbread Jul 21, 2019
    MMuralidhar , Jul 21, 2019 :
    led notification customization works?
  14. B1534416414518
    Donut Jul 21, 2019
    B1534416414518 , Jul 21, 2019 :
    Hi Team,
    I installed it and everything seems ok except very few crashes.
    One query, are you able to check BATTERY USAGE DATA? Mine is not working. Can anybody pls confirm so that I could rest in peace :)?
    Thanks
    Gaurav
  15. sunit6k
    Donut Jul 21, 2019
    sunit6k , Jul 21, 2019 :
    Even I have the same bug. Battery usage is always at 0 mins.
  16. B1534416414518
    Donut Jul 21, 2019
    Yes, could anyone solve it by doing some workaround?
  17. DTHayakawa
    DTHayakawa , Jul 21, 2019 :
    gestures are working fine, but only in portrait. in landscape gestures are practically unusable.
  18. doncarlodc
    laikexpert likes this.
  19. B1534416414518
    Donut Jul 21, 2019
    Hi, what about Battery Usage Data? Is it working for you ?
  20. I1563685348344
