201
Android Q Developer Preview 3 for OnePlus 6 and 6T
  1. doncarlodc
    Cupcake Jul 21, 2019
    doncarlodc , Jul 21, 2019 :
    is not working yet
  2. G_kishor_raghwani
  3. laikexpert
    Froyo Jul 21, 2019
    laikexpert , Jul 21, 2019 :
    Only battery usage dont work.
    All other its OK.
    P.S.
    3 for OnePlus 6
    (Its my daily driver.)
  4. jaygatsby9909
    Honeycomb Jul 21, 2019
    jaygatsby9909 , Jul 21, 2019 :
    Has there been any word on why some devices (mainly OP6) had the bug we're seeing crashing constantly from setup. Where safemode is your only way to get around in the system long enough to rollback? Some OP6 owners act like it's the greatest update ever but other OP6 owners (and some 6T) can't even set the phone up because settings literally crashed about every 5 seconds. Why the huge difference? What is the difference between mine and Mario (from telegram) that has the EXACT same phone (OP6 Red 128GB, 8GB RAM), model, storage and RAM. Any ideas or fixes because I haven't found anything yet.
  5. devesh darji
    Gingerbread Jul 21, 2019
    devesh darji , Jul 21, 2019 :
    Bro Even though everybody has same model but One plus must have used different vendor in different region or may be different vendor for some batches. So it affects. This problem is for every company.
  6. chazey2
    Jelly Bean Jul 21, 2019
    chazey2 , Jul 21, 2019 :
    Sure you did, but the first time I installed DP via TWRP I forgot the format data. The phone booted normal and the first stage set up sim usage find WiFi etc then jumped straight into 'updating' what you normally see at the end of the set up process, after fingerprint, Google and font set up and then started acting up freezing - crashing ETC.
    A quick back to TWRP and fresh install this time factory reset and format data type 'yes' and all was peachy creamy. I've not had any issues at all apart from the known battery stats thing.
  7. cristian.raduca
    cristian.raduca , Jul 21, 2019 :
    Hi guys. I have installed DP3 since 2 days and works ok. The only issue I found disturbing was the fact is sets sound on mute. Practically I go to settings and unmute the sound for media and I still can not hear any music on it. It sets itself back on mute. Anyone had this issue on their device?
  8. Owski97
  9. Levibrod
    Eclair Jul 21, 2019
    Levibrod , Jul 21, 2019 :
    Has anyone confirmed the cause for the audio issues on the OnePlus 6? Some people are saying no issues, others are saying it's always muted. Has anyone been able to clarify the issue? I'm asking specifically for OP6.
    cristian.raduca likes this.
  10. Levibrod
    Eclair Jul 21, 2019
    Which version of TWRP do you have installed, and is it working well? Also have you achieved root with magisk? I'm on the latest open beta (22) with TWRP and magisk, just wondering if it's all working ok on Android q.
  11. cristian.raduca
    mine is op6
  12. chazey2
    This Twrp
    https://forum.xda-developers.com/on...overy-unofficial-twrp-touch-recovery-t3860815
    Reboot to recovery (above Twrp) Factory reset- Slide - Advanced - tick all but USB- Wipe - Format Data type 'yes' - press tick.
    Note I store files on USB OTG stick, you maybe back to MTP to replace files.
    Install Q- Back to Twrp home
    Install Twrp .zip- Home
    Reboot - Reboot Recovery
    Install Q - Home
    Install Twrp.zip -Home
    Install Magisk 19.3 - Home
    Wipe - Factory reset - Slide
    Format Data - type 'yes'
    Reboot System -Set Up
    This what I did and have no issues on Q DP, this will install Q on both slots.
    Z1532734961753 and Levibrod like this.
  13. J1538982176332
  14. CharlieCats
    Eclair Jul 21, 2019
    CharlieCats , Jul 21, 2019 :
    Can you guys run Antutu and Geekbench on your OP6 running Android Q DP3.
    Some say it's good enough to be a daily driver. thanks
  15. Priyankgohil 10
    Froyo Jul 21, 2019
  16. Owski97
  17. Priyankgohil 10
    Froyo Jul 21, 2019
  18. kalpak11
    kalpak11 , Jul 21, 2019 :
    Vibration feedback is too strong. I checked settings and kept it minimal them also it's not changing.
  19. sw_btn
    Froyo Jul 21, 2019
    sw_btn , Jul 21, 2019 :
    I see an oxygen os 9.0.5 in Android q dp3....shouldn't it be oxygen is 10...as with pie op changed nomenclature based on Android version....by changing oos 6...to oos 9.....or may op team seems to have forgotten this notification..
  20. sahil_pradhan__
    Eclair Jul 21, 2019
    sahil_pradhan__ , Jul 21, 2019 :
    check in customisation section there will be preset theme
