201
Android Q Developer Preview 3 for OnePlus 6 and 6T
  1. Maverick2.0
    KitKat Jul 21, 2019
    Maverick2.0 , Jul 21, 2019 :
    Horizon light working?
  2. Maverick2.0
    KitKat Jul 21, 2019
    Benchmark results are hardly any indication of whether a phone is daily driver material or not.
  3. C1563700891670
    Cupcake Jul 21, 2019
    C1563700891670 , Jul 21, 2019 :
    if i am updating from android pie to android q dp3.Will it wipe out my data??
    as they only said that about updating from dp2 to dp3
    They didn't mention about updating from android pie
  4. Maverick2.0
    KitKat Jul 21, 2019
    Same. It will wipe all your data.
    C1563700891670 likes this.
  5. Cpt. Price
    Froyo Jul 21, 2019
    Cpt. Price , Jul 21, 2019 :
    Yes it works
  6. Priyankgohil 10
    Froyo Jul 21, 2019
  7. cmd42
    Eclair Jul 21, 2019
  8. O1557657932852
    O1557657932852 , Jul 21, 2019 :
    I'm on Android pie and I wish to install Android q on my phone but I have no idea how to install the downloaded version please help?
  9. Trevor.Hawkes
    Ice Cream Sandwich Jul 21, 2019
    Trevor.Hawkes , Jul 21, 2019 :
    You asked for help.
    Don't try it is the only help you need.
  10. O1557657932852
    well if you say so but may I ask why shouldn't I try
    J1549931514118 likes this.
  11. cristian.raduca
  12. J1549931514118
    J1549931514118 , Jul 21, 2019 :
    please Read the fix for that
  13. cristian.raduca
  14. cristian.raduca
  15. jaygatsby9909
    Honeycomb Jul 21, 2019
    jaygatsby9909 , Jul 21, 2019 :
    I'm not rooted or using TWRP. But mine was a fresh install.
  16. jaygatsby9909
    It's not a vendor issue. And it's not the same for every company.
  17. devesh darji
    Gingerbread Jul 21, 2019
    devesh darji , Jul 21, 2019 :
    Vendor means part suppliers. Different batches have different hardware suppliers.
  18. jaygatsby9909
    Yeah, I know what a vendor is. So basically though what you're saying is no, you don't know a fix and you actually have no idea why it's happening. This isn't like 10 phones. It's happening here, other countries on other continents. It's happening to the 6 and 6T at XDA (but not to their 7 or 7 Pro). And it's not different vendors because the chips are all Qualcomm and the GPU is Qualcomm. Most companies that make phones use the same vendor for every phone. So that is a fallacy that that is causing the problem. XDA even recommended that you don't install it on the 6 or 6T.
  19. Nate76
    Nate76 , Jul 21, 2019 :
    I have the 6t international model on Verizon. After setup and about 45 minutes of use the system UI started crashing with screen going black. Reboot several times with no new results. Booted into safe mode, worked flawless. However as I needed full use of cellular and data, ended up rolling back to android pie of course through safe mode. I decided to try again, same results other than removing SIMS allowed usage not being in safe mode along with being able to eventually get system to work with SIMS reinstalled. On occasion a few times a day now, the system UI crashes. The issue has to do with the SIMS and the LTE signal.
    Note: I the Tiles (airplane mode, data, wifi) setup next to each other in the notification trey to accomplish the steps below.
    When System UI crashes and screen goes black:
    Pull the SIMS or go into safe mode and follow steps
    Go into airplane mode
    Turn on WiFi
    Insert SIMS (with WiFi on)
    Turn off airplane mode
    Quickly turn off data as airplane is switching off
    Turn data back on after cellular signal is back
    It may take 1 or 2 times, it has worked several times for myself. I get full usage of the phone again until it crashes again. I believe the actual issue is VoLTE. It does work, but unstable.
    O1557657932852 likes this.
  20. jaygatsby9909
    I'm on AT&T so no VOLTE for me. But it may, oddly, be a carrier issue. I've heard that suggested before but not sure how that would cause the system to crash constantly.
