210
Android Q Developer Preview 3 for OnePlus 6 and 6T
  1. R.K.Dey
    Gingerbread Jul 22, 2019
  2. JosephElsave
    JosephElsave , Jul 22, 2019 :
    OnePlus launcher keep crashing and there is no option to report bugs some times play store also crash these are the problem I face. OnePlus thanks for the update pls fix these bugs soon
    Rajnarayan.durga likes this.
  3. Jitesh_Meena
    Cupcake Jul 22, 2019
  4. ajudi46
    ajudi46 , Jul 22, 2019 :
    launcher won't crash if you use default OnePlus icon pack
    I'm using default launcher with gesture and launcher isn't crashing
  5. JosephElsave
    I used default icon pack but it crash
  6. JosephElsave
    download msmdownload tool and flash stable build after download dp3 and flash it
    Levibrod likes this.
  7. JosephElsave
  8. chazey2
    Jelly Bean Jul 22, 2019
    chazey2 , Jul 22, 2019 :
    Search xda for fast boot ROM from memory guides section of OnePlus 6 forum. This will put you back to stock or beta your choice.
  9. G_Kashif_Akhtar_VhHk
    G_Kashif_Akhtar_VhHk , Jul 22, 2019 :
    So far so good for me, i don't seem to getting as many Launcheer crashes and other issues you guys have reported it, but i do have a quesrtion, how did you get it on dark mode?
    edit - never mind ignore me, i found out how.
  10. laikexpert
    Froyo Jul 22, 2019
    laikexpert , Jul 22, 2019 :
    I use Nova Launcher Pro
    without any problems.
    I use H2O Icon pack
    P.S.
    for OnePlus 6
    I use it everyday
  11. ashishzone
    Eclair Jul 22, 2019
    ashishzone , Jul 22, 2019 :
    any updates on the performance of the Developer Preview 3 ?
    daily driver material? suggestions on what to use and what not to use to avoids bugs?
    thank you
  12. ashishzone
    Eclair Jul 22, 2019
    what about the launcher crashes? battery performance? the latest gesture navigation??
    thanks!
  13. U1528949738327
    Eclair Jul 22, 2019
  14. Ching_Nam_Ip
    Ching_Nam_Ip , Jul 22, 2019 :
    Use original icon pack don't change it
  15. OPDev
    OPDev , Jul 22, 2019 :
    Hello , my launcher crashed too. The solution is you need to go into apps on settings and open the OnePlus Launcher. Then , clear the data and it wont crash anymore.
  16. OPDev
    Hello, after using for 3 days , i have not encountered any laucher crash after clearing data at the OnePlus launcher on settings.
    The battery performance works really well and as quite good or even better than Pie.
    The latest gesture navigation works , but its sometimes buggy. It did like lagged on horizontal mode tho.
    ashishzone likes this.
  17. M1540957238124
    M1540957238124 , Jul 22, 2019 :
    I have a OnePlus 6T and everytime I try to install the latest Android Q beta, after it reboots it bricks my phone and I can get an error that says "build version and hw version is not match" and I have to restore it. Can anyone explain why this keeps happening and if there's a way to get around it?
  18. devesh darji
    devesh darji , Jul 22, 2019 :
    Are you on Latest Stable Build?
  19. joelpaul13
  20. M1540957238124
    Yes I am. I've tried DP3 from the latest stable build and also from the latest open beta build. I get the same error each time.
