182
Android Q Developer Preview 3 for OnePlus 6 and 6T
  1. Ching_Nam_Ip Gingerbread Jul 23, 2019
    Ching_Nam_Ip, Jul 23, 2019 :
    for those who have can't adjust the sound volume you need to shutdown your phone and turn on it again then problem solved ***DON'T PRESS REBOOT *** otherwise you can't solve the problem
  2. vilson_316 Cupcake Jul 23, 2019
    vilson_316, Jul 23, 2019 :
    I have downloaded the same but unable to decrease the volume.
  3. E1545974892602 Eclair Jul 23, 2019
    Staufengalen likes this.
  4. Achyut230 Eclair Jul 23, 2019
  5. Achyut230 Eclair Jul 23, 2019
    sankar.kaza likes this.
  6. ashishzone Eclair Jul 23, 2019
    ashishzone, Jul 23, 2019 :
    Update:
    There's a possibility of System Ui crashes from time to time when using a third party launcher. I experienced this when I was using LawnchairV2 as my default launcher.
    Is anyone else experiencing this? any solutions?
  7. VishalYadav17 Cupcake Jul 23, 2019
    VishalYadav17, Jul 23, 2019 :
    I has installed the dp3 and my data got erased.. I had a backup in my laptop.. even after placing it in my phone I can't use the OnePlus switch to restore it.. it isn't working and my phone's data is all lost
    Darrenc81 likes this.
  8. Darrenc81 Froyo Jul 23, 2019
    Darrenc81, Jul 23, 2019 :
    would be lovely if people can actually read... we'd be back on page 5 not 50 pages of the same comments.
    if you don't know what you're doing installing a developer preview DON'T INSTALL IT. simple. just wait. use the stable release, or the very good open beta.
    Q may well hit open beta soon... it will be far better than this release, which, apart from a couple of often mentioned bugs is actually pretty stable if you follow the instructions.
    if you've converted your T-Mobile to international again, wait. don't install. you modified your device so don't expect everything to be simple.
    constantly asking people for links that are on the very first post is not helpful to anyone.
  9. S1527958166239 Eclair Jul 23, 2019
    S1527958166239, Jul 23, 2019 :
    Any one have solution for chrome bugs..?
    please share the ideas,
    My issue is..
    After download the apk I am unable to install and unable to find in download file which is in the file manager.
  10. S1527958166239 Eclair Jul 23, 2019
    killerOneplus5t likes this.
  11. Bandarshan Cupcake Jul 23, 2019
  12. Oneplusabhiphilic Cupcake Jul 23, 2019
  13. Oneplusabhiphilic Cupcake Jul 23, 2019
  14. D1548741071266 Cupcake Jul 23, 2019
    D1548741071266, Jul 23, 2019 :
    I downloaded it today but I'm not satisfied as I expected to be. Boot lasts around 40 seconds instead of 10-15 seconds on pie and also the applications are not so responsive and are lagging sometimes. Gestures are not quite responsive and LED notifications are not working wich ends with a settings crash. In my opinion this is not a daily driver. Maybe you can wait for beta 4 or 5.
  15. T1557356728312 Cupcake Jul 23, 2019
  16. cliveren13 Cupcake Jul 23, 2019
    cliveren13, Jul 23, 2019 :
    Hi thanks for this i was wondering what i was doing wrong as the first 2 dp worked for me and this one wouldnt figured it was checking for version of phone
  17. Darrenc81 Froyo Jul 23, 2019
    one thing that helped massively, and has helped other people is to flash normally. reboot and complete setup. then reboot into recovery (hold volume down) and do a full wipe of data and cache (factory reset).
    then reboot, setup again and use normally.
    don't know why but that sorted issues I had when I first tried DP3...
    I have a feeling the issues with chrome can be resolved but don't have time to test a couple of things today.
    probably going to flash back to open beta, and come to Q in a month or so when we have a beta
  18. G_Cake_101_Vbfv Cupcake Jul 23, 2019
    G_Cake_101_Vbfv, Jul 23, 2019 :
    I know Barclays says it isn't supported on Android Q (because of some ROM signatures not being present as of DP2), can anyone test to see if DP3 is working with Barclays?
  19. JuAnCaStRoP Gingerbread Jul 23, 2019
    JuAnCaStRoP, Jul 23, 2019 :
    Hey, do you know how to get it working on the t-mobile variant
  20. ironass KitKat Jul 23, 2019
    ironass, Jul 23, 2019 :
    It was announced at the release of the T-Mobile (USA) carrier minority variant, back in October 2018, that they would not be eligible for Beta firmware...
    "Will the OnePlus 6Ts purchased at T-Mobile be eligible for the Beta Program?
    T-Mobile OnePlus 6Ts will not be eligible for the Beta Program.
    Source
    However, like the Open Beta releases, there is a workaround for the tech savvy, there is @Jacksummers post, back on Android Q Developer Preview 2...
    https://forums.oneplus.com/threads/...or-oneplus-6-6t.1054690/page-16#post-20447580
    Kytharsis and JuAnCaStRoP like this.
