210
Android Q Developer Preview 3 for OnePlus 6 and 6T
  1. B_Wrath
    Marshmallow Jul 26, 2019
    B_Wrath , Jul 26, 2019 :
    All Android Q related queries must be done on the dedicated thread.
    That is expected out of any competent DP tester.
    Dgafking0480 and Sun90 like this.
  2. SoniaB
    Nougat Senior Moderator Jul 26, 2019
    Kytharsis and Sun90 like this.
  3. Scherpenseel
    KitKat Jul 26, 2019
    Scherpenseel , Jul 26, 2019 :
    Because this is not a beta but a developer preview. Cant you read?
    Define "safe". It's "safe" to download, but there will be many bugs when installing.
    When it's ready.
    Kytharsis and Dgafking0480 like this.
  4. ebproject
    Eclair Jul 26, 2019
  5. U1528949738327
    Eclair Jul 26, 2019
  6. kannasms
    Cupcake Jul 26, 2019
  7. ngydat
    KitKat Jul 26, 2019
    ngydat , Jul 26, 2019 :
    As the name implies, it isn't a beta but a developer preview which means this isn't meant for "dummies" (I'm just using your words so don't take it personally)
  8. Scherpenseel
    KitKat Jul 26, 2019
    And you've reported your bug like a developer tester should? Or are you just complaining without contributing anything to this thread?
    Kytharsis and ngydat like this.
  9. G_Huynh_Tinh
    Gingerbread Jul 26, 2019
    petertinh likes this.
  10. Ronak1998
    Ronak1998 , Jul 26, 2019 :
    CURRENTLY I'M ON OPEN BETA 15 OF 6T SO CAN I DIRECT UPDATE FROM LOCAL PACKAGE? OR I HAVE TO DOWNGRADE FIRST?
  11. Sun90
    Starting Point Expert Jul 26, 2019
    Sun90 , Jul 26, 2019 :
    First you need to stop posting in all caps as it's deemed shouting on any forum.
    You can upgrade directly.
    But be aware that it's going to wipe all your data on the phone, so do a backup first and also read the very first post of this thread for all the needed information before you proceed.
    Kytharsis likes this.
  12. Ching_Nam_Ip
  13. Ching_Nam_Ip
    Ching_Nam_Ip , Jul 26, 2019 :
    If you fail to upgrade than you need to downgrade first using the rollback pack in the post
    R1545390189269 likes this.
  14. Ronak1998
    thx
  15. Kumaravel_10
  16. Cervantes
    Lollipop Moderator Jul 26, 2019
    Cervantes , Jul 26, 2019 :
    Hi
    The Android Q Developer Preview 3 thread is a thread of questions and/or commentary
    Please, You read the first post thread Android Q
    Thread merged
  17. hansba
  18. sanki_man
    Honeycomb Jul 26, 2019
  19. Z1541695834610
  20. Z1541695834610
