210
Android Q Developer Preview 3 for OnePlus 6 and 6T
  1. Xcutioner
    Honeycomb Aug 4, 2019
    Xcutioner , Aug 4, 2019 :
    People on here are extremely impatient ... just read the former posts for the answer before repeating the same thing a million times...
    amirhussaini93 likes this.
  2. Dgafking0480
    Ice Cream Sandwich Aug 4, 2019
    Dgafking0480 , Aug 4, 2019 :
    it's like that on anything here, and it's always the same stuff. people should really just start looking back at previous posts to get there answers for stuff. it drives me crazy
    Xcutioner likes this.
  3. amirhussaini93
    amirhussaini93 , Aug 4, 2019 :
    Aasim K
    That is not mind game.Thats how development works.
    If the build is ready ,they will roll it out.​
    Some people don't want understand on that pal.
    They assume cooking ROM is easy like 1,2,3 and release. [e]1f602[/e]
    People too excited to install, and after that, a ton of reply saying my phone have problem, GPay not working, Netflix not working and so on.
    Aasim K and Dgafking0480 like this.
  4. Dgafking0480
    people are hurry flash hungry and don't read things before hand and then want to complain about it
  5. amirhussaini93
    absolutely true pal. xD
    like i reply previous post, really shocked that OxygenOS Q DP4 release first before HydrogenOS. Before this, HydrogenOS release first, later OxygenOS. (based on history both ROM)
    i keep monitor on oneplusbbs (china) to see hint and what next things on incoming OOS. (except China stuff on H2OS like cloud so on)
    Dgafking0480 likes this.
  6. Faceetious
    Cupcake Aug 4, 2019
    Faceetious , Aug 4, 2019 :
    Im currently running my Oneplus 6 on open beta 23 and i want to fladh the h2 OS but whenever im trying to flash it via local upgrade its saying system update installation failed.....idk what to do please help me
  7. I1527143849229
    Cupcake Aug 4, 2019
  8. amirhussaini93
    Sir, why you want try H2OS? Is this because incoming H2OS Q DP4 or just want try it?
    HydrogenOS (H2OS) is for China community, which is have bloatware and cloud server, but no Play Store and have Google component. (such like Google Play Service (old, need update after install latest Play Store), Google Contact/Calender Sync and mamy more)
    Just install latest Play Store, and Google Contact (search in Play Store) and open Google Contact app and start sync) and everything works fine. (takes time to it work) But, latest H2OS (including Q DP) not like older H2OS that much easier sync Contact from Google account.
    Please dont use Google Installer that MIUI user used to make Play Store (and Google account works on China ROM) also don't flash GApps, result will be error/failed because GApps (Google component) is already there, just not updated.
    Oh ya, don't forget to remove bloatware on H2OS. You gonna hate it. Hahaha
    If you install via TWRP is much easier and can play which version you want (Stable/Open Beta/Q DP) and something bad happen, you can access your data and do backup. (stock recovery don't have it, or already have, but need do some command (adb) or so on)
    About your problem, i don't have experience playing H2OS via local upgrade because always playing them via TWRP. Try check build number, make sure OOS not too latest than H2OS, or use latest H2OS that latest than OOS. (ouch, too many words latest hahaha)
    I like playing H2OS, it's give hint/clue about what features, bugs that will implemented on incoming OOS. [e]1f601[/e]
    * Sorry if I'm wrong. Just my 0.20MYR opinions and experience. (*_ _)人
  9. T1542364278079
    Donut Aug 4, 2019
  10. VaguelyWoo
    Gingerbread Aug 4, 2019
    VaguelyWoo , Aug 4, 2019 :
    T1542364278079
    i am already download that file but i can't open file
    this is error msg​
    rename it and remove "(1) .jar" from the update name
    And if you are going to use local update, you need to place the file in your Root folder
  11. amits1720
  12. amirhussaini93
    Yeah true. But i wonder what apk Settings icon he download.
    No need to install that apk right to downgrade?
    Or need to install go ease downgrade process?
  13. Faceetious
    Cupcake Aug 4, 2019
    This is what it is saying whenever I'm trying to flash the android q dp 3.....please help!!!urgent
  14. VaguelyWoo
    I have no clue why he has that APK, i think he can't even install it. but I think he was talking about the file above
  15. H1536339109863
    Cupcake Aug 4, 2019
  16. amirhussaini93
    You can do it on Recovery. (watch out, wrong choose will wipe all your data)
    Or use this app, easy to use by Google name Files.
    https://play.google.com/store/apps/details?id=com.google.android.apps.nbu.files
    Or our File Manager can do it. (watch out, first option will delete all apk that you download on your phone. My bad choose that hahaha)
    But, I always use Files from Google.
  17. Faceetious
    Cupcake Aug 4, 2019
    how to downgrade?.....whenever I'm trying to downgrade it saying installation cannot be done cause the version is lower
  18. Faceetious
    Cupcake Aug 4, 2019
    thank you so much for your help
  19. VaguelyWoo
    you need the right downgrade package, which you should be able to find in the first post by OnePlus on this thread
  20. Faceetious
    Cupcake Aug 4, 2019
    I'm running open beta 23 on my OnePlus 6 can you just give me the correct file to downgrade it to stable
