209
Android Q Developer Preview 3 for OnePlus 6 and 6T
  1. MMuralidhar
    Gingerbread Jul 18, 2019
  2. kouzelnik3
    Honeycomb Jul 18, 2019
  3. VaguelyWoo
  4. VaguelyWoo
    VaguelyWoo , Jul 18, 2019 :
    When Google has released the Official Version
  5. Sirfan570@
    Eclair Jul 18, 2019
  6. papatasos
    Cupcake Jul 18, 2019
    papatasos , Jul 18, 2019 :
    i confirm this bug.
  7. rahuldw181
    Ice Cream Sandwich Jul 18, 2019
  8. VaguelyWoo
    You can but your data will wipe
  9. papatasos
    this build is not for you if you asking these questions
    AarKay2311 likes this.
  10. Sai Adiraju
    Eclair Jul 18, 2019
    Sai Adiraju , Jul 18, 2019 :
    is it stable enough for daily use...
    doesn't need to be super stable for me
    i just need the basics to work properly
    ryano891 likes this.
  11. VaguelyWoo
    From what I've seen it seem to work okay for daily driver if you're ready to take a data loss
    Maverick2.0 likes this.
  12. J1534403770769
    Froyo Jul 18, 2019
  13. VaguelyWoo
    Try downgrading the launcher or install another one?
  14. Sai Adiraju
    Eclair Jul 18, 2019
    no worries about data loss I am looking at a YouTube video to check general performance if it's fine I will make the switch
  15. VaguelyWoo
    I saw the video of Hydrogen and from what I've seen from this tread it seems okay but that's up to you. if it weren't for the data loss I would be on Q rn
  16. Priyanshu Sharma
    Jelly Bean Jul 18, 2019
  17. Maverick2.0
    KitKat Jul 18, 2019
    Maverick2.0 , Jul 18, 2019 :
    Hey man! I am on OB 22 on my 6 and am tempted to try this out. So, are banking apps and Netflix etc working fine?
    And could you please check if Smart Display is working and tell what it's like? Thanks.
  18. Maverick2.0
    KitKat Jul 18, 2019
    I would say sometime in September. But that's a rough guess.
  19. kdngk
    Eclair Jul 18, 2019
    kdngk , Jul 18, 2019 :
    Hey Guys, I have installed the DP3 on my OP6, And after using it for approx an hour or so, continuously, I can say that DP3 is stable enough to be used as a daily driver. However, I faced two temp glitches:
    1. During initial setup, I couldn't enter the password for the WIFI due to the frozen keyboard. This glitch was gone once I locked/unlocked the screen.
    2. Sound & vibration: Phone was stuck showing itself on Vibration but still it was ringing. Neither the Alert Slider was working nor the Ring/Media/Alarm volume options. However after a reboot this was also gone.
    3. Launcher Crash: One Plus launcher crashes while opening apps like Play Store, Drive, Photos. However this is not a continuous issue that I got every time I opened the apps.
    4. Notification privacy is not working. Even if you select "Show sensitive content only when unlocked" the notification content is visible.
    Just reboot your device once after the DP3 setup is done and it will behave normally.
    5. "LED Notifications" setting isn't working, the settings app crashes everytime.
    Let me use it for a while if you are looking for an in-depth review.
    Amivel, Maazperwez, dex2grigg and 4 others like this.
  20. goddv
    Donut Jul 18, 2019
    goddv , Jul 18, 2019 :
    It's DP5
