185
Android Q Developer Preview 3 for OnePlus 6 and 6T
  1. SXeral Donut Aug 12, 2019
  2. Installazion Cupcake Aug 12, 2019
  3. Installazion Cupcake Aug 12, 2019
    Installazion, Aug 12, 2019 :
    And why do I cant swipe from the bottom to go back and from the left and right side to go back?
  4. pastalex42 Eclair Aug 13, 2019
    pastalex42, Aug 13, 2019 :
    They replaced OnePlus gestures with stock Google gestures
  5. G_Rahul_Agarwala_qHkX Gingerbread Aug 13, 2019
    G_Rahul_Agarwala_qHkX, Aug 13, 2019 :
    tum open beta mei ho, pehle downgrade karo stable version wala, fir sidha sidha dp update krna same process mei.
  6. Owski97 Gingerbread Aug 13, 2019
    Owski97, Aug 13, 2019 :
    pls. write in English only
  7. G_Rahul_Agarwala_qHkX Gingerbread Aug 13, 2019
    bro, you need to downgrade the version first to stable version, and then update the latest stable version which you will instantly receive via OTA, after that only the downloaded developer preview can be successfully installed,
    in open beta, the build number of the software is higher than the developer preview 3
    that is why so much work have to be done. that's the only way.
    hope you understand it now.
  8. Y1528545317429 Cupcake Aug 13, 2019
  9. Ching_Nam_Ip Gingerbread Aug 13, 2019
  10. rahuldw181 Ice Cream Sandwich Aug 13, 2019
    rahuldw181, Aug 13, 2019 :
    i feel so, may be at the end of the month.
    Xcutioner likes this.
  11. Installazion Cupcake Aug 13, 2019
    Installazion, Aug 13, 2019 :
    Is that now the DP3 or something different, some say its DP5 but is that confirmed?
    And even with that, there are some bugs still left:
    -WIFI wont work (only with a Hotspot by my Telekom router)
    -Internal Speakers dont work
    -some Apps inside of a folder doesnt have a picture
    -Much space is left on the bottom of the phone, like 3cm
    So now only things that i dont like:
    -You can only swipe from right or left , why?
    -in many subfolder settings you have to press a button to see all of the settings, again why?
    I know that this is a DP!
  12. adibbx Donut Aug 13, 2019
    adibbx, Aug 13, 2019 :
    WiFi works for me properly. and as for the swipe left or right, you can change the navigation gesture to navigation bar in settings easily.
  13. ebproject Eclair Aug 13, 2019
    Installazion and prathameshp95 like this.
  14. amirhussaini93 Ice Cream Sandwich Aug 13, 2019
    amirhussaini93, Aug 13, 2019 :
    What is your KWGT setup? Like what plugin you install. Like Dope Music Widget or what.
    Look nice.
  15. ebproject Eclair Aug 13, 2019
    ebproject, Aug 13, 2019 :
    Do you mean that music widget?
    Xcutioner and amirhussaini93 like this.
  16. amirhussaini93 Ice Cream Sandwich Aug 13, 2019
  17. ebproject Eclair Aug 13, 2019
    It's in the Andromeda KWGT pack. I edited mine and made my own version though.
  18. amirhussaini93 Ice Cream Sandwich Aug 13, 2019
    Thanks pal. Later i back to Q DP3, i used that pack.
    You know that latest Spotify Beta dont have widget. Idk is bug or they remove widget or they redesign it and later put it back.
  19. ebproject Eclair Aug 13, 2019
    Just make your own, stock widgets are usually not good anyway.
    amirhussaini93 and Xcutioner like this.
  20. MS929 Cupcake Aug 13, 2019
    MS929, Aug 13, 2019 :
    I keep going back and forth between android pie and android q. I go back to pie because it's way more stable and my apps crash way less often then they do on Android Q. Then I come back to Q for the new navigation gestures. I need someone else's opinion on what I should do.
