74
Android Q Developer Preview 3 for OnePlus 7 Pro and 7
  1. Manu J.
    OxygenOS Product Staff Member Jul 18, 2019
    Manu J. , Jul 18, 2019 :
    OnePlus 7 Series gets Android Q Developer Preview 3!
    As the name suggests, this build of Android Q is best suited for developers and early adopters. As it is still in an early stage of development, we do not recommend flashing this ROM if you have little or no experience in software development or flashing custom ROMs. Proceed at your own risk!
    Caution: You should understand the risk of BRICKING your phone, read the instructions carefully and be 100% sure of what you are doing, and please always backup your important data before flashing.
    Known Issues
    1. Application compatibility problems
    2. You may face stability issues.
    3. User data will be cleared for DP1 & DP2 upgrading
    Please note: This instruction is only for OnePlus 7/7 Pro, and please make sure the battery level is above 30% and minimum 3GB of available storage space.
    MP version = Stable official version
    DP version = Developer Preview version
    MP to DP upgrade guide—via Local OTA Update
    Note: This upgrade method will erase all the contents of the phone, please be sure to backup first.
    1. Download the latest ROM upgrade zip package from the specified server.
    2. Copy the ROM upgrade package to the phone storage.
    3. Go to Settings -> System -> System Updates -> Click top right icon -> Local upgrade -> Click on the corresponding installation package -> upgrade -> System upgrade completed to 100%.
    4. After the upgrade is complete, click Restart.
    5. The phone will boot into recovery mode to format user data, it will reboot again after formatting.
    6. Update successful.
    DP to MP rollback guide - via Local OTA update
    2. Copy the Rollback package to the phone storage.
    Ready to get started on the Android Q Beta?
    Upgrade from DP2 to DP3 (data loss, please back up)
    Want to go back to Android Pie? Download the Rollback package from the links below:
    As always, please share your feedback through https://forums.oneplus.com/feedback/.
    Never Settle.
  2. atmsriram
    Gingerbread Jul 18, 2019
    FlixbusLennart likes this.
  3. JigneshJain
  4. Huigiebaby
    Ice Cream Sandwich Jul 18, 2019
  5. derLenno
    The Lab - OnePlus 6 Reviewer Jul 18, 2019
  6. Marek_Orovnicky
    Honeycomb Jul 18, 2019
  7. sechinov
  8. Loper_fan
    Froyo Jul 18, 2019
    Loper_fan , Jul 18, 2019 :
    Lmao. I couldn't have said it better. Time to go bug hunting.
    G_Akshay_thakur_YNvb and knrd like this.
  9. Huigiebaby
    Huigiebaby , Jul 18, 2019 :
    Jezus christ... "Local Upgrade: The version of your selected package is lower than that of the current system..."
    No love for the 9.5.10 user. ;(
    Ok, I'll rollback to Pie then try again.
    @OnePlus, why do you make this such a hassle... *sigh*
    knrd, Dhruvit Jain, rdtecno71 and 3 others like this.
  10. Loper_fan
    Froyo Jul 18, 2019
    Just noticed that myself. Download rollback package. Then after that downloading q dp 3
  11. Moin2200
    KitKat Jul 18, 2019
  12. Moin2200
    KitKat Jul 18, 2019
    Moin2200 , Jul 18, 2019 :
    Hopefully this one will be a bit more stable.
  13. kannaa_kr
    Froyo Jul 18, 2019
  14. Cassoli_2017
    Donut Jul 18, 2019
  15. PGopalakrishnan
    Froyo Jul 18, 2019
  16. PGopalakrishnan
    Froyo Jul 18, 2019
  17. PGopalakrishnan
    Froyo Jul 18, 2019
  18. TheMysticalShaman
    TheMysticalShaman , Jul 18, 2019 :
    I am definitely not going to jump onto this. I will be watching for feedback and reviews to see if it's stable enough to install or not. The other two Developer Previews were garbage, very unstable. Plus the system settings need to be more complete. The other two versions of DP had just a few system settings, not enough.
    knrd and loucas971 like this.
  19. the_reckoner
    dj.g00s3 likes this.
  20. TheMysticalShaman
    Colday_96, knrd, ducksonetime and 3 others like this.
