74
Android Q Developer Preview 3 for OnePlus 7 Pro and 7
  1. JigneshJain
    Gingerbread Jul 21, 2019
    JigneshJain , Jul 21, 2019 :
    yes simple is the name of that theme in customisation
  2. Furkan.sumon
    Donut Jul 21, 2019
    joydeep33.dey and Shajahankm like this.
  3. malcolm1995
    Cupcake Jul 21, 2019
    malcolm1995 , Jul 21, 2019 :
    are you talking about dp 2 or this one?
  4. Rahuls1ngh
  5. F_Dylan_Murzello_Klvx
    Eclair Jul 21, 2019
  6. gt5679a
    Ice Cream Sandwich Jul 21, 2019
    gt5679a , Jul 21, 2019 :
    Thanks. Was trying to avoid a factory reset as it is only a couple bank apps that are giving me an issue, but I may give it a try.
  7. gt5679a
    T-Mobile using a OnePlus international.
    eqbirvin likes this.
  8. joydeep33.dey
    Eclair Jul 21, 2019
    joydeep33.dey , Jul 21, 2019 :
    I am facing issue with adaptive brightness. screen is dimming on and off. Any one can confirm if you are also facing the same issue.
  9. JoseReyes69
    JoseReyes69 , Jul 21, 2019 :
    Yes, I too have same issue
  10. eqbirvin
    Eclair Jul 21, 2019
  11. joydeep33.dey
    Eclair Jul 21, 2019
    1. another issue is you can not change text colour and icon colour. Specially if you choose a custom colour like I change it to yellow.
    2. some issue with facebook with dark theme. comments are completely white.
  12. joydeep33.dey
    Eclair Jul 21, 2019
  13. IBCHH
  14. docnok63
    Jelly Bean Jul 21, 2019
  15. niko_bellic
    Froyo Jul 21, 2019
    niko_bellic , Jul 21, 2019 :
    Can't able to rollback from my android Q dp3 . its just showing move installation package to rrot directory.
    But the file was already in directory.
    Kindly help.
  16. niko_bellic
    Froyo Jul 21, 2019
    Heck the Oneplus developers, the rollback OS downloaded was not showing in local upgrade even it was in the root directory. At last , It was the name extension of the file downloaded its showing as .zip.jar . After renaming the file with an extension .zip then its showed up in the local upgrade.
    knrd and Shajahankm like this.
  17. c3drik67
    Honeycomb Jul 21, 2019
    c3drik67 , Jul 21, 2019 :
    Hello people how is the life of the battery In this build comparative to the official pie build. Thanks for your answer.
  18. Shajahankm
  19. ChristianEngen
    Froyo Jul 21, 2019
    ChristianEngen , Jul 21, 2019 :
    had to download the latest dp3 and install over the previous. now the sound works
    docnok63 likes this.
  20. Maximilian Gaedig
