74
Android Q Developer Preview 3 for OnePlus 7 Pro and 7
  1. Drakthorian2
    Gingerbread Jul 27, 2019
    Drakthorian2 , Jul 27, 2019 :
    First off I had to make another acc cause i can't access my original google acc I used due to deleting it.
    Second off. I couldn't answer that I am using the unlocked version myself :)
  2. Drakthorian2
    It's not something I've heard about, unfortunately. Anyone else who has this bug, that can chip in on this?
  3. mjsava
    Donut Jul 27, 2019
    mjsava , Jul 27, 2019 :
    The VZW/AT&T issue occurs on unlocked versions as an FYI....
    eqbirvin likes this.
  4. G_Tony_Garris_IbTi
    Cupcake Jul 27, 2019
    G_Tony_Garris_IbTi , Jul 27, 2019 :
    That's what I did 2 times still a no go
  5. MKaderco
  6. docnok63
    Jelly Bean Jul 27, 2019
    docnok63 , Jul 27, 2019 :
    Hmmmm. Force stop the app and clear its cache? If that doesn't work, you might want to clear its storage (although you'll lose your call log, so back that up with OnePlus Switch first.)
  7. M1559834330967
    Eclair Jul 27, 2019
    M1559834330967 , Jul 27, 2019 :
    guys , I am unable to downgrade to pie , it keeps saying place the folder in the root directory which is the root directory btw?
  8. eqbirvin
    Eclair Jul 27, 2019
    eqbirvin , Jul 27, 2019 :
    What is your carrier?
  9. P1526573641184
    Donut Jul 27, 2019
  10. docnok63
    Just by coincidence, this happened to me today. The way I fixed it was to pull down notifications and toggle the speaker "on" and then "off" again while in a call.
    Android Q is version 10. OOS 9.5.GM21AA
  11. hotiger7
    Donut Jul 27, 2019
  12. docnok63
    Jelly Bean Jul 28, 2019
    docnok63 , Jul 28, 2019 :
    Only if you're SIM unlocked and on international software to start. I'm on T-Mobile variant with those conditions before installing and it's running fine. If you need to get SIM unlocked, see the XDA thread. That's how I did it.
  13. amaroney55
    Cupcake Jul 28, 2019
  14. POORNIMAGUPTA2@G
  15. amaroney55
    amaroney55 , Jul 28, 2019 :
    if I am not mistaking u have to adb to get some features working. Google q beta adb features.
  16. Luca_Marangon
    Froyo Jul 28, 2019
    Luca_Marangon , Jul 28, 2019 :
    [ OP7 9.5.7 NO ROOT]
    I tried to install Android Q DP3 on OP7 and it won't let me, it says I already have a higher version installed.
    I didn't know I had Android R on board,
    Ho provato ad installare Android Q DP3 su OP7 e non me lo permette, dice che ho già una versione superiore installata.
    Non sapevo d'avere Android R a bordo
  17. amaroney55
  18. X1554211828531
    Gingerbread Jul 28, 2019
    X1554211828531 , Jul 28, 2019 :
    u must downgrade to oxygen os 9.5.5
  19. Luca_Marangon
    Froyo Jul 28, 2019
  20. X1554211828531
    chk YouTube how to downgrade OOS
    I flash 9.5.5 firmware using TWRP
