73
Android Q Developer Preview 3 for OnePlus 7 Pro and 7
  1. Billyrouth
    Froyo Aug 3, 2019
    Billyrouth , Aug 3, 2019 :
    o have the pro and I haven't received it either.
  2. GauravMajithia
    Donut Aug 3, 2019
    GauravMajithia , Aug 3, 2019 :
    Takes time to rollout to all regions.
    At least it shows you that Dp4 is out.
    For onePlus7 it shows you are on latest.. :p
  3. GauravMajithia
    Donut Aug 3, 2019
    I have Topic apart from Prod Dp4.
    Netflix does not work for My OnePlus7 DP3. Says Sorry we could not reach Netflix Service (-14). Contracted Netflix they are saying network is blocked for this app or internet is not available.
    I check permission everything looks ok. Cleared data for the app.
    Any idea?
  4. Billyrouth
    Froyo Aug 3, 2019
    just got it.
  5. VJK21
    Gingerbread Aug 3, 2019
    VJK21 , Aug 3, 2019 :
    share update log if u have.
  6. docnok63
    Ice Cream Sandwich Aug 3, 2019
  7. GauravMajithia
    Donut Aug 3, 2019
  8. Dgafking0480
    Dgafking0480 , Aug 3, 2019 :
    are you on TMobile? can I assume that there is actually service in dp4 now?solid as a daily?
  9. docnok63
    docnok63 , Aug 3, 2019 :
    Historically, HydrogenOS builds have been about two weeks before OOS builds as they work out the kinks for the international build. As the latest is a H2OS build for OP7Pro, I'd say they're 2 or 3 weeks away from OOS release for both devices even though it's very stable.
    Yes, you'll have service as long as you're SIM unlocked. And yes, this is a daily driver as long as you don't mind not having Google Assistant or VoWiFi. Auto-rotate works much better and so do gestures.
  10. Billyrouth
    Froyo Aug 3, 2019
    Wrong DP4 is out for the 7plus.
  11. Dgafking0480
    damn I'm not sum unlocked oh well I can wait lol
  12. docnok63
    Do you have a non h2os.com link?
  13. Billyrouth
    Froyo Aug 3, 2019
    Don't have a link,just use Oxygen Updater and make sure in the setting of the Oxygen updater the advanced mode is checked.
  14. Billyrouth
    Froyo Aug 3, 2019
    docnok63 likes this.
  15. Cooldrewf
    Froyo Aug 3, 2019
    Cooldrewf , Aug 3, 2019 :
    I downloaded the dp without wiping my phone and I love gestures and don't want to go back to the regular nav buttons. When downloaded everything worked perfectly ,it booted right up to nova launcher. Like said dp4 would wipe fingerprints it did but face unlock worked. The Google Assistant worked and Android Q was running ok with the usual animation stutter every 4th to 6th animation depending on which animations you are doing. Then I switched to the gestures and everything went to hell. I do realize it's bc Android Q gestures don't support 3rd party launchers yet but the animation glitch from home screen going to recents and whenever you like close an app back to the homescreen. I ended up having to wipe my phone when downgrading back to Pie. Don't make the same mistake I did! If you use a 3rd party launcher do not download any of these Betas if you want to use gestures!
  16. G_GOPALAKRISHNAN
    Donut Aug 3, 2019
  17. Billyrouth
    Froyo Aug 3, 2019
    Uhm, Most people on here are already aware that the new navigation won't work with 3rd party launcher on android q, google has already said that they won't work.
  18. JoseReyes69
    JoseReyes69 , Aug 3, 2019 :
    Clear cache from recovery. That's what I have to do
    GauravMajithia likes this.
  19. Cooldrewf
    Froyo Aug 3, 2019
    you could try deleting Netflix and if you search up how to use adb commands to flash an app on YouTube you can follow that to flash the Netflix apk onto your phone. this might help not sure .
  20. GauravMajithia
    Donut Aug 3, 2019
