74
Android Q Developer Preview 3 for OnePlus 7 Pro and 7
  1. Billyrouth
    Froyo Aug 3, 2019
    Billyrouth , Aug 3, 2019 :
    Well of course it is cause that's the phone I have and you had stated that only hydrogenos had been updated to dp 4 on the 7pro. so what's your point?
  2. emann56
    Donut Aug 3, 2019
  3. Virgiel
    Froyo Aug 3, 2019
  4. emann56
    Donut Aug 3, 2019
    emann56 , Aug 3, 2019 :
    3.8.13
  5. PGopalakrishnan
    Eclair Aug 3, 2019
  6. Darrenc81
    Gingerbread Aug 3, 2019
    Darrenc81 , Aug 3, 2019 :
    oh cool DP4... here we go again...
    meanwhile in the 6t thread cue lots of jealously
  7. GauravMajithia
    Donut Aug 3, 2019
    GauravMajithia , Aug 3, 2019 :
    Hi,
    I think you got confused. I was discussing about DP4 for OnePlus7 and not for OnePlus7 Pro.
    While we already know OnePlus7 Pro received DP4, but that is not the case for OnePlus7.
    I hope this will clear the confusion. :)
  8. Virgiel
    Froyo Aug 3, 2019
    Virgiel , Aug 3, 2019 :
    when using gestures, there is still an unused space at the bottom of the screen as if the navigation bar was turned on. Is it bug or do i need to make a full wipe?
  9. emann56
    Donut Aug 3, 2019
    Are you seeing it on all the apps or just some? I see it when I'm on the keyboard and this community app.
  10. mjsava
    Donut Aug 3, 2019
    mjsava , Aug 3, 2019 :
    I can confirm the System UI crashes for Verizon users has been resolved. I've been running DP4 since it dropped and not one System UI crash....so far. Guessing AT&T users will work now too.
  11. Virgiel
    Froyo Aug 3, 2019
    yea, just when im typing
  12. emann56
    Donut Aug 3, 2019
    I also see it on the Speedtest.net app.
  13. disliknown
    Cupcake Aug 3, 2019
  14. badcrow
    Cupcake Aug 3, 2019
    badcrow , Aug 3, 2019 :
    hi oneplus 7 pro why after getting the Android Q dp4 installation i always get this error
  15. KevinT.
    Froyo Aug 3, 2019
    KevinT. , Aug 3, 2019 :
    Aren't you aware that what you had installed is a Developer Preview, and such crashes are expected given that the Developer Preview is a pre-release software? Pre-release software is, most of the time, not daily driver material, and shouldn't be installed if you're not ready for that.
    Most likely Google and OnePlus are aware of this issue, and will be fixed, at the latest, by the time when Android Q is released publicly as stable by Google and OnePlus starts releasing their Open Betas or Stable Android Q-based OxygenOS.
    Maverick2.0 likes this.
  16. Maverick2.0
    KitKat Aug 3, 2019
    Maverick2.0 , Aug 3, 2019 :
    You got it as an OTA Update? Were you on DP 3?
  17. badcrow
    Cupcake Aug 3, 2019
    same problem occurs dp3 error and now they are using xda dp4 installation am i doing it wrong ? When the factory settings are activeted it is working but when ı turned on and off it gives an error again.
  18. emann56
    Donut Aug 3, 2019
    I was on DP3 and got it through the official OTA Update.
  19. Maverick2.0
    KitKat Aug 3, 2019
    That's strange. DP s usually require a sideloading. No OTA s. Was your data affected in any way?
    How's the experience?
