74
Android Q Developer Preview 3 for OnePlus 7 Pro and 7
  1. G_Christos_Giamalidis_TW
    Cupcake Aug 3, 2019
    G_Christos_Giamalidis_TW , Aug 3, 2019 :
    i installed it and i found a few bugs phonebook and messages not working disappeared from the dock i found them in other place. any idea?
  2. ChinghissKhan
    Cupcake Aug 3, 2019
    ChinghissKhan , Aug 3, 2019 :
    I have enabled the Update Method to Q preview and the "Advanced mode" and I am getting: "The latest system update is: Android Q Developer Preview 3 (Rev. 2)" File name is: OnePlus7Oxygen_1413.X.04_OTA_004_all_1907191948_a6e18b0b3e594cb1.zip!
    Am I right, this is the OLD DP3 or the new DP4?
    I am on Q DP3!!!
  3. ChinghissKhan
    Cupcake Aug 3, 2019
    You need to ENABLE "Advanced Mode" !!!
  4. siyaantu
    Eclair Aug 4, 2019
  5. NickMidd91
    Gingerbread Aug 4, 2019
    NickMidd91 , Aug 4, 2019 :
    this is the old DP 3 but when installing this update you can get the new update from oxygen updater app from the Google play store
  6. GauravMajithia
    Donut Aug 4, 2019
    GauravMajithia , Aug 4, 2019 :
    That is same DP3 which you are using.. No need to Install again...
  7. yashwant24
  8. adityarmrc
    Donut Aug 4, 2019
  9. antnyhills
    Cupcake Aug 4, 2019
    antnyhills , Aug 4, 2019 :
    Android Auto does not appear to be working in Beta 4. Plugging in will simply not launch anything, my head unit will sometimes show a blank screen while phone's plugged in.
    snatschi likes this.
  10. JigneshJain
    azu1414 likes this.
  11. snatschi
    Cupcake Aug 4, 2019
    snatschi , Aug 4, 2019 :
    yep same here
  12. F_Tarun_Ambati_
    Eclair Aug 4, 2019
  13. VaibhavBhargava
    Lollipop Aug 4, 2019
    VaibhavBhargava , Aug 4, 2019 :
    It's been removed from this build
  14. GauravMajithia
    Donut Aug 4, 2019
  15. GauravMajithia
    Donut Aug 4, 2019
    Only Pro Version
  16. GauravMajithia
    Donut Aug 4, 2019
    Not sure if it was planned for OnePlus7.. On Stable it did not even have option to customise it. On developer preview there is an option but does not work
    adityarmrc likes this.
  17. T1564901264956
    Cupcake Aug 4, 2019
  18. W1564910174213
    Cupcake Aug 4, 2019
    W1564910174213 , Aug 4, 2019 :
    you just need to click on that error..choose info then go to storage and clear cache and data and it should be fine
  19. bibhab1976
    bibhab1976 , Aug 4, 2019 :
    i tried and living with it for more than 12 hrs. notfound any problem till now
    Ahmc9 likes this.
  20. G_Christos_Giamalidis_TW
    Cupcake Aug 4, 2019
    G_Christos_Giamalidis_TW , Aug 4, 2019 :
    nova launcher gestures not working for me and the widgets i am trying to change the dimensions to make them smaller and i cant staying big . I tried with a weather widget ,google calendar and other . Except these pretty stable for me , way better than pie and the new gestures awesome!!!! Dark theme on Facebook and facebook messenger sucks , the letters on messenger is white and u cannot read anything even with the dark theme that is default in the settings of messenger. Have u tried dark theme ?
