74
Android Q Developer Preview 3 for OnePlus 7 Pro and 7
  1. antonyjen
    Jelly Bean Aug 4, 2019
  2. Olesol
    Cupcake Aug 4, 2019
    Olesol , Aug 4, 2019 :
    Will installing the Android Q Developer Preview erase backup too? I have Android P installed
    Edit: it will not wipe
  3. RaMi83
    Froyo Aug 4, 2019
    RaMi83 , Aug 4, 2019 :
    yes, but developer review 4 is out there and i installed it and it didnt wipe my data
    Z1558843799122 and Olesol like this.
  4. ArunKannan1
    Donut Aug 4, 2019
    ArunKannan1 , Aug 4, 2019 :
    I have updated to android q developer preview 3 from 9.5.2. The major problem for my device is the audio is very low. please help me with a solution. anyone tell me a solution. thank you
  5. Olesol
    Cupcake Aug 4, 2019
    antonyjen likes this.
  6. y2k1ltd
    Gingerbread Aug 4, 2019
  7. snatschi
    Cupcake Aug 4, 2019
    RaMi83 and y2k1ltd like this.
  8. Jeji.George
    Eclair Aug 4, 2019
    Jeji.George , Aug 4, 2019 :
    DP 4 on OP7Pro
    Google Pay working
    Fingerprint need to set again (DP4 will not wipe datas)
    Volte working
    Edits
    Horizon Light Notification not working (It will work after turn on the setting for ambient display new notification, customization for Horizon light is there but no change, it will stay on blue color )
    There is an alignment issue when press back button on certain apps.
    Else everything work fine, can use as a daily driver.
    y2k1ltd and Predict23 like this.
  9. RamQ
    Froyo Aug 4, 2019
    RamQ , Aug 4, 2019 :
    Have you encountered an issue where sometimes while on a dark screen, half vertical side of the screen is slightly lighter than the other half ?
  10. Jeji.George
    Eclair Aug 4, 2019
    No...
  11. ChristianEngen
    Froyo Aug 4, 2019
    ChristianEngen , Aug 4, 2019 :
    yes, i have. but i guess it's a Nova launcher issue. like the half navkey bars with the back line. with no backline it's normal. but everything works with OnePlus launcher and lawnchair v2
  12. Dothinh
    Cupcake Aug 5, 2019
    Dothinh , Aug 5, 2019 :
    I installed DP4, can I use the rollback file on #1 post to go back to Pie?????
  13. Jeji.George
    Eclair Aug 5, 2019
    Jeji.George , Aug 5, 2019 :
    Ya, You can roll back to android P. using the roll back file. remember roll back to P will erase your all datas
    Dothinh likes this.
  14. Dothinh
    Cupcake Aug 5, 2019
    thank you
    jejigeorge1 likes this.
  15. F_Dylan_Murzello_Klvx
    Eclair Aug 5, 2019
  16. wouthaksteen
    Cupcake Aug 5, 2019
    wouthaksteen , Aug 5, 2019 :
    Has anyone found google backup to be working? The setup said there was no backup found, although I certainly have one linked to my account.
  17. apat26
    Froyo Aug 5, 2019
    apat26 , Aug 5, 2019 :
    yes, it worked for me. Gave me option to choose from backups and it then restored
  18. AlexCahlenstein
    Cupcake Aug 5, 2019
    AlexCahlenstein , Aug 5, 2019 :
    90Hz doesn't seem to be working egen though it is enabled in settings. Is it possible to enable it via ADB?
  19. AlexCahlenstein
    Cupcake Aug 5, 2019
  20. AlexCahlenstein
    Cupcake Aug 5, 2019
    Hmm it started working again after reboot
