74
Android Q Developer Preview 3 for OnePlus 7 Pro and 7
  1. jaarochafree
    Cupcake Aug 26, 2019
  2. Y1563034088237
    Y1563034088237 , Aug 26, 2019 :
    That happens whether desktop mode is enabled or not; with DP3 I experimented with the desktop mode, but that had an issue with hiding the soft navigation keys (when the activity on the "desktop" screen would enter immersive fullscreen, the soft navigation keys would hide their graphics, but leave a black band at the bottom of the screen).
    Because of this, I switched the desktop mode off, so I am not sure if this issue still persists with DP4. Other than the black strip, the desktop mode worked fine for me (but it did require a custom launcher or Q/desktop aware activities).
  3. techguy378
    techguy378 , Aug 26, 2019 :
    Will the OnePlus 7 Pro support Project Mainline's automatic Android updates? Has this been enabled yet in the beta?
  4. jaarochafree
    jaarochafree , Aug 26, 2019 :
    in DP4 it seems that the same problem persists or worse, since when I connect to the second screen nothing comes out. just a light gray bar at the bottom edge and the entire black screen. What custom launcher did you use or Q/ desktop aware activities.
  5. Y1563034088237
    That is the correct behavior. I patched UserLAnd for external displays, I do not really use external displays for other than linux stuff.
  6. jaarochafree
    You can helping me making that. I never used UserLand before. My idea is to use at external touchscreen. But I thinks the android Q is to green yet.
  7. jaarochafree
  8. m.tariq
    Cupcake Aug 27, 2019
    m.tariq , Aug 27, 2019 :
    dear in beat version game Space APK find its in-built
  9. jaarochafree
    Cupcake Sep 5, 2019
    jaarochafree , Sep 5, 2019 :
    Hey somebody tested the new Android Q beta(beta 5).
    I read in XDA so many issues is fixed.
  10. jaarochafree
    Cupcake Sep 5, 2019
  11. S1565442037611
    Cupcake Sep 6, 2019
    S1565442037611 , Sep 6, 2019 :
    "Local Upgrade: The version of your selected package is lower than that of the current system..." Plss help to solve this problem
