202
Android Q Developer Preview 4 for OnePlus 7 Pro and 7
  1. Tob_eu
    Cupcake Aug 7, 2019
    Tob_eu , Aug 7, 2019 :
    I tried swiping from the the side to the right/left at the top part of the screen but same result:no menu, only one move back
  2. Atul Menon
    Gingerbread Aug 7, 2019
    B1560530162014 likes this.
  3. Killian COMPAGNON
  4. Woodp3ck3r
    Donut Aug 7, 2019
    Woodp3ck3r , Aug 7, 2019 :
    Having issues with Bluetooth headsets, using the Sennheiser Momentum on-ear, when connected, sound volume popup keeps appearing with every touch on the device.
    Live wallpapers turn totally blank when movement stops.
    Little artifacts on the lower corners.
    And while working on a Google spreadsheet and screen goes off, really difficult to wake up the phone. No image.
    RandyManLB likes this.
  5. Jay234shah
    Eclair Aug 7, 2019
    Jay234shah , Aug 7, 2019 :
    whats the problem is some one asking for new updates for there models. everyone needs new updates on there phones.
    so please stop you to tell anyone to don't ask.
  6. boomny
    Donut Aug 7, 2019
    boomny , Aug 7, 2019 :
    L1541501419579
    Can anyone say if google pay works? (I know the main post says no, but sometimes stuff does work even when they say it doesn't)​
    mine works fine. in fact i removed my primary card and readded just to be sure. all my banking apps work too with the exception of chase.
    atLeeroyJenkins likes this.
  7. boomny
    Donut Aug 7, 2019
    has anyone noticed bad battery drain on standby for average signal strength wifi networks?
    also, when navigation bar is enabled there's a weird white/grey line appears around it in some apps including OnePlus community app.
  8. L.S.K
    Eclair Aug 7, 2019
    L.S.K , Aug 7, 2019 :
    I'm trying to downgrade my phone back to pie but the phone isn't reading the file ? it's a jar file , anyway around this ?
  9. GraveDigger176
    GraveDigger176 , Aug 7, 2019 :
    Delete the jar at the end and all is fine
  10. boomny
    Donut Aug 7, 2019
    change extension to zip
  11. Rupak.apk
    Cupcake Aug 7, 2019
    Rupak.apk , Aug 7, 2019 :
    I am using DP3 on my OP7 but I Didn't receive an OTA for DP4. I tried going to the system update option but it says that the software is up to date. please help!
  12. Leon.861
    Froyo Aug 7, 2019
    Leon.861 , Aug 7, 2019 :
    that's Google's plan, not oneplueses.
    OnePlus could release this beta as a open beta if they wanted
    Drakthorian2 likes this.
  13. Leon.861
    Froyo Aug 7, 2019
    we don't know for sure if it will be available for the 5t, according to the "release cycle" of OnePlus it won't.
    but if you consider that the OnePlus 3 and 3t got pie, even if they really shouldn't have due to the cycle, there is a chance.
  14. srini0301
    Ice Cream Sandwich Aug 7, 2019
    srini0301 , Aug 7, 2019 :
    if u r not aware I'm not talking about oxygen OS ,I'm talking about Android 10.0 .
  15. Leon.861
    Froyo Aug 7, 2019
    you don't know anything. now I get it
    OXYGEN OS 10 IS WILL ONLY AVAILABLE WITH ANDROID 10.
    OXYGEN OS 9 IS ONLY AVAILABLE WITH ANDROID 9.
    oxygen os is the god damn skin on top of ANDROID
  16. srini0301
    Ok kid do what ever u want to .
  17. Leon.861
    Froyo Aug 7, 2019
    just get your mind together, inform yourself about Android/oxygenos and then we'll talk again. you can't get the latest oxygen os if you don't get the latest Android
  18. srini0301
    Kid I'm talking about Android version and time schedules ,if u work with Google en light me with correct schedules and then u r free to say that I'm wrong .
  19. vistaabalaji
    Eclair Aug 7, 2019
    vistaabalaji , Aug 7, 2019 :
    then manually donwload and do local update. dp3 to dp4 wont erase ur data
  20. Kwangoesdk
    Donut Aug 7, 2019
    Kwangoesdk , Aug 7, 2019 :
    sorry you are wrong!
    look at Android version and look at oxygenos version
    this already shows you are wrong!
    srinivas0301 likes this.
