201
Android Q Developer Preview 4 for OnePlus 7 Pro and 7
  1. Huigiebaby
    Honeycomb Aug 13, 2019
    Predict23 likes this.
  2. DogeAlpha
    DogeAlpha , Aug 13, 2019 :
    I'm not running on developer preview and I have a question for those who run it
    Is android beam still there? Or is it a way to make it work if it isn't there anymore?
    I know google removed it but I saw that Huawei phones running android Q beta (with Huawei's Emui on top) still have it and it still works(It's called Huawei beam, same as android beam)
  3. Ajsat3801
    Gingerbread Aug 13, 2019
    Ajsat3801 , Aug 13, 2019 :
    android beam is present... for now...
  4. vriesdejoop
    Ice Cream Sandwich Aug 13, 2019
  5. rahulsipu
    Froyo Aug 13, 2019
    rahulsipu , Aug 13, 2019 :
    After update android Q 4, every ringtone play is Jerk. speaker very annoying and sound tear while playing the music or ringtone. I think this problem happen only in Android Q4. while I back to stable OS it's work fine.
  6. Manzo9120
    Cupcake Aug 13, 2019
    Manzo9120 , Aug 13, 2019 :
    I installed a clean DP4 on my Oneplus 7 pro but I keep getting this bug message whenever the phone is charging...Can someone help not sure how to fix or if it's just a bug I have to deal with for now
  7. Nic2112
    Nic2112 , Aug 13, 2019 :
    I have the following to contribute for those who are thinking of going to DP4.
    I downloaded the update package, ran a local upgrade, rebooted, wiped to factory default, and re-setup the phone without restoring a backup. I don't have a custom recovery, root, magisk or anything else that's not stock.
    Dual SIM, WIFI, texting, calling, all apps and games I tried worked (expect for the RSA SecurID app which still thinks the phone is in airplane mode). Yes there are some display glitches here and there but it's very small and doesn't make me want to go back to stable just for that. Call volume is fine, I had no problems with bluetooth and three devices (Honda car, Bose quiet comfort headsets, Jabra 65t earbuds), no app crashes or other problems.
    The most visible visual problem that I see often is the gap at the bottom of the screen that sometimes doesn't have the navigation buttons and isn't used by the app.
    Android auto in a definitive no. I tried to disable it, clear data and cache, re-install it from apkmirror, it will load up, car will detect a phone, pairing seems to work, and then the screen on the car will say "Loading..." and nothing else happens.
    So for me, not having android auto is somewhat of a problem and add to that the fact that I can't use my RSA password token app makes DP4 not daily driver ready for me yet but I believe it will be good for most people to use every day.
    I also noticed that this thread is not a sticky anymore so I have a feeling the next release will be made available by OnePlus soon.
    Georgeoneplus7pro likes this.
  8. Manzo9120
    that seems to have worked....thank you very much!
  9. raaghuu
    Froyo Aug 13, 2019
    raaghuu , Aug 13, 2019 :
  10. Sir_Pool_de_Float_MD
    Sir_Pool_de_Float_MD , Aug 13, 2019 :
    Did you try the ADB shell command to remove system apps? Perhaps removing the system app for AA will allow the version from the Play Store to install. I did notice while I was on DP4 that there was an update to the built-in app, but still the same behavior after installing it.
  11. docnok63
    docnok63 , Aug 13, 2019 :
    I wouldn't read too much into this thread not being a sticky anymore. The French thread is still a sticky. It's probably an error by a mod.
  12. raaghuu
    Froyo Aug 13, 2019
    Don't kill our hopes and dreams... [e]1f604[/e]
    RandyManLB and Georgeoneplus7pro like this.
  13. Chayan Ray
    Chayan Ray , Aug 13, 2019 :
    I tried to install DP 4 in my oneplus 7, but after rebooting the phone is stuck in the booting screen, and I am not able to switch off the phone. What to do?
  14. raaghuu
    Froyo Aug 13, 2019
  15. F_Suryakant_Kharatmal_Tc
  16. UndeadAD
    Eclair Aug 13, 2019
    UndeadAD , Aug 13, 2019 :
    anybody realized the sound for phone calls has been on the bottom speaker even when not in speaker
  17. R_d_M
    Froyo Aug 13, 2019
    R_d_M , Aug 13, 2019 :
    All fine over here ..
    No problem
  18. Chayan Ray
    Thank You
    I wiped cache in recovery mode, and the oneplus comfortably booted
  19. UndeadAD
    Eclair Aug 13, 2019
  20. KingShashank
    KingShashank , Aug 13, 2019 :
    I would ....with increasing one Plus prices , the limit of my card is 300$ and 7 pro costs 670$ any ideas?
    Hey, will you buy my kidney?
    RandyManLB likes this.
