149
Android Q Developer Preview 4 for OnePlus 7 Pro and 7
  1. Smokee464 Cupcake Aug 14, 2019 at 10:17 AM
    Smokee464, Aug 14, 2019 at 10:17 AM :
    Ok, thanks!
  2. iampun33t Gingerbread Aug 14, 2019 at 10:38 AM
  3. vistaabalaji Eclair Aug 14, 2019 at 10:47 AM
    vistaabalaji, Aug 14, 2019 at 10:47 AM :
    closed beta- 4 updates/months
    open Beta- 2 updates/months
    Stable- 1 or 2 months per update.
  4. Smokee464 Cupcake Aug 14, 2019 at 11:04 AM
    Smokee464, Aug 14, 2019 at 11:04 AM :
    And now we are in what direction? closed or open Beta?
  5. vistaabalaji Eclair Aug 14, 2019 at 11:06 AM
    vistaabalaji, Aug 14, 2019 at 11:06 AM :
    open betam closed beta only for elite and well active knowledged users only
  6. Arsath1994 Eclair Aug 14, 2019 at 2:52 PM
  7. J1557410854041 Cupcake Aug 14, 2019 at 2:58 PM
  8. Nic2112 Froyo Aug 14, 2019 at 3:06 PM
    Nic2112, Aug 14, 2019 at 3:06 PM :
    I have a great solution: go back to stable.
  9. J1557410854041 Cupcake Aug 14, 2019 at 3:18 PM
    Georgeoneplus7pro likes this.
  10. Ajsat3801 Froyo Aug 14, 2019 at 3:19 PM
    Ajsat3801, Aug 14, 2019 at 3:19 PM :
    Battery life seems fine to me.... try wiping data and see it works...
  11. Nic2112 Froyo Aug 14, 2019 at 3:43 PM
    Nic2112, Aug 14, 2019 at 3:43 PM :
    I'm not sure what you expect. There is no "Drain the battery" option in DP4 that you can disable, it's not stable software, it might have debugging enabled which slows things down, it's simply not meant to work the same way stable does.
    You can try wiping to factory default but that's about it.
  12. DJSubterrain Ice Cream Sandwich Aug 14, 2019 at 3:48 PM
    DJSubterrain, Aug 14, 2019 at 3:48 PM :
    This. Is. Not. The. OnePlus. 5T. Forum.
    Could we make this any more obvious?
    G_Pol_Bonastre_rHEG likes this.
  13. deypratim Donut Aug 14, 2019 at 4:09 PM
    deypratim, Aug 14, 2019 at 4:09 PM :
    It is not stable version, battery last for only 6.30 hrs(SOT), some apps not responding well, in India UTS, Samsung Galaxy Watch not giving me SMS and some other notification, camera behaviour is not not good, sluggish, heating problem during use and charging(too much hot). Used it for 3 days and go back to Pie. Now its giving me 8+ hrs SOT.
  14. rmpcsekar Donut Aug 14, 2019 at 4:22 PM
  15. rmpcsekar Donut Aug 14, 2019 at 4:32 PM
  16. sandiprc2008 Cupcake Aug 14, 2019 at 5:05 PM
  17. Nic2112 Froyo Aug 14, 2019 at 5:09 PM
    sandiprc2008 likes this.
  18. H1561960043803 Eclair Aug 14, 2019 at 5:17 PM
    H1561960043803, Aug 14, 2019 at 5:17 PM :
    unlocked how? bootloader or sim? sim had to be unlocked to be able to switch to international version I thought.
  19. UndeadAD Eclair Aug 14, 2019 at 5:18 PM
    H1561960043803 likes this.
  20. svickey29 Cupcake Aug 14, 2019 at 5:21 PM
