156
Android Q Developer Preview 4 for OnePlus 7 Pro and 7
  1. grillrd Cupcake Aug 6, 2019
    grillrd, Aug 6, 2019 :
    Yes, same issue. Unable to downgrade since the file doesn't show in local after moving it to the internal storage.
    #81
  2. Easwaramurthy Gingerbread Aug 6, 2019
    #82
    ran.777 and Djok like this.
  3. wjrandon Cupcake Aug 6, 2019
    wjrandon, Aug 6, 2019 :
    Android Audio doesn't work with DP4 on the OP7P. Once plugged into a vehicle it crashes in a few seconds. I've seen a lot of draw over glitches also. Random icons appearing on the dock and occasional when flipping between applications the app will draw itself over the notification bar on top. Glad I tried it. Going back to stable.
    #83
  4. Deemigs Donut Aug 6, 2019
    Deemigs, Aug 6, 2019 :
    i agree with you. I hope the devs find a solution to this
    #84
  5. docnok63 Gingerbread Aug 6, 2019
    docnok63, Aug 6, 2019 :
    It's the same file just on a different server now, so there is no need to change anything on your phone. See screenshot below.
    Your file ends with .zip.jar. Remove the .jar part and you will be able to see the file.
    #85
    grillrd likes this.
  6. Deemigs Donut Aug 6, 2019
    Happens to me as well. I simply rename it and delete the .jar
    #86
    grillrd likes this.
  7. Georgeoneplus7pro Gingerbread Aug 6, 2019
    Georgeoneplus7pro, Aug 6, 2019 :
    But about performance, GPS accuracy, wifi, mobile data, speed, graphics, no one says anything, nothing good about this Q? Just trouble and new skin? No improvement? We are interested in the perceived performance, not the benchmark coefficients.
    #87
  8. Deemigs Donut Aug 6, 2019
    I did for two days and didn't like it because of the keyboard. Although the new experience is great, I just really find it hard to type using this build.
    #88
    Georgeoneplus7pro likes this.
  9. Deemigs Donut Aug 6, 2019
    With regards to the connection speed, most of the time I do not receive notifications on time... At first I thought it was because of both the battery optimization and sleep standby being enabled, so I disabled both to see the difference. However, I still got the same result. Notifications from apps lile messenger, whatsapp, and slack are still delayed.
    #89
  10. TechForum Froyo Aug 6, 2019
    TechForum, Aug 6, 2019 :
    Yeah I faced the above ones. But strangely with me game crashed more if I didn't launched it through Game space. Yeah gaming mode works fine but Fnatic mode I doubt so. If someone plays with their data on it automatically disables the data by showing no sim error. So this is one issue I faced.
    #90
  11. Georgeoneplus7pro Gingerbread Aug 6, 2019
    :) Similar to switching from XP to Vista, a nasty system with a new interface.
    #91
  12. docnok63 Gingerbread Aug 6, 2019
    I was using for a couple of days, but Google Assistant was broken for me on this build. I read many forum posts across the internet and tried several solutions to fix the problem. I narrowed it down to when setting up the Assistant for "OK Google" voice match, it came back "Assistant already knows your voice" or something like that. Once that happens, the mic breaks for all voice searches (Assistant, Play Store, etc) and voice to text is broken in Swiftkey Beta. For me, not being able to to voice was a deal breaker for me. I had no problems on DP3 and I'm rolled back to 9.5.11 and no problems there. I know it's a Google account issue with DP4 because if you remove the Google account, Assistant works again. I'll wait for the next build to try again.
    Other than that, for me, this was a daily driver build. OnePlus has been doing very well incorporating OOS touches into Q. I love their software and update speeds!!! :D
    EDIT: I forgot, the phone answering in speakerphone and having to fight to get it off speakerphone mode was annoying as well.
    #92
  13. Atul Menon Donut Aug 6, 2019
    #93
  14. Atul Menon Donut Aug 6, 2019
    Atul Menon, Aug 6, 2019 :
    device Op7 or pro
    #94
    antonyjen likes this.
  15. Q1529908435633 Gingerbread Aug 6, 2019
    #95
    ran.777 likes this.
  16. om252345 Cupcake Aug 6, 2019
    om252345, Aug 6, 2019 :
    I installed DP4 on my OnePlus 7 pro. I was on Android Pi, 9.5.11, After update device restarted. but all my data , apps, call logs everything was as it is. In the instructions it says it will wipe out all data after reboot. That didn't happen to me. Is it normal??
    #96
    Deemigs and Q1529908435633 like this.
  17. Q1529908435633 Gingerbread Aug 6, 2019
    Q1529908435633, Aug 6, 2019 :
    Yeah it's just normal. Check out a video about this on YouTube then you will understand.
    #97
    Deemigs likes this.
  18. Deemigs Donut Aug 6, 2019
    I believe so... happened to me as well
    #98
    Q1529908435633 likes this.
  19. Q1529908435633 Gingerbread Aug 6, 2019
    #99
    ran.777 and _Lxurxnz_ like this.
  20. Atul Menon Donut Aug 6, 2019
    you found any speaker bug
    crackling sound
