201
Android Q Developer Preview 4 for OnePlus 7 Pro and 7
  1. JmcRepair33
    Honeycomb Aug 19, 2019
    JmcRepair33 , Aug 19, 2019 :
    Then you didn't move it to the right directory let me show you were you have to move the upgrade downgrade file I'll post a screen shot
  2. JmcRepair33
    Just paste it in the main folder the first folder that comes up move it there and it will show up in the local upgrade of you renamed and removed the. Jar or. Tar I don't remember which one you have to remove so look it up but make sure you move it and paste it to root directory like in the screen shot with the file manager
    MFaisalT.89 and E1540434125775 like this.
  3. E1540434125775
    Cupcake Aug 19, 2019
    E1540434125775 , Aug 19, 2019 :
    thank you. appreciate your help
    Pinracer13 likes this.
  4. MFaisalT.89
    Donut Aug 19, 2019
    MFaisalT.89 , Aug 19, 2019 :
    Rename the downgrade file. it end with ".zip.jar".
    You have to delete the ".jar" part and leave it ending with ".zip".
    Now it will be readable when moved to the root directory.
    Be careful, it will wipe all your data.
    H1561960043803 likes this.
  5. JmcRepair33
    Thank you for clarifying that for him
    H1561960043803 and MFaisalT.89 like this.
  6. MFaisalT.89
    Donut Aug 19, 2019
  7. darknagel
    Donut Aug 19, 2019
    darknagel , Aug 19, 2019 :
    Today after 1 Week of use of DP4 i got this error
    After a restart its fine but some time after the problem comes back. Anybody has this too? Going back to pie :(
  8. MFaisalT.89
    Donut Aug 19, 2019
    This actually happened to me on Pie when I was using SoundCloud. But it only happened on the SoundCloud navigation part, no taps responding or anything.
    However it did not happen on the actions toggles, neither did it happen with me on Q.
  9. JurijKZ
  10. darknagel
    Donut Aug 19, 2019
    This happens in the full system. Soundcloud is not installed.
  11. JmcRepair33
    Go to the app clear data force stop and reboot
  12. Nic2112
    Ice Cream Sandwich Aug 19, 2019
    Nic2112 , Aug 19, 2019 :
    of course DP6 this week, specially since there is no dp5 yet
  13. JmcRepair33
    Bro our dp5 will be based off the dp6. Just a heads up. After that more then likely final beta
  14. Nic2112
    Thanks, your valuable contribution is always appreciated... bro...
  15. JmcRepair33
    No problem all of us make one big community to help everyone out
  16. AvengersAssemble
  17. vriesdejoop
    vriesdejoop , Aug 19, 2019 :
    when OP announced it in the forum.....
  18. JmcRepair33
    Rule number 1 don't ask for when something is coming out
  19. drhide2020
    Donut Aug 19, 2019
    drhide2020 , Aug 19, 2019 :
    Rolled back to 9.5.11
    Why?
    -DP4 signal is sooooo bad, my google fi almost stopped working on it and keep disconnecting, even if connected the speed on 4G+ almost 56Kb
    -oneplus Pie gestures away better than the DP4 one, i have it on my Pixel 3 and i can say it is so bad, wishing oneplus will keep its gestures as it is much better than android Q one
  20. JmcRepair33
    drhide2020
    Why?
    -oneplus Pie gestures away better than the DP4 one, i have it on my Pixel 3 and i can say it is so bad, wishing oneplus will keep its gestures as it is much better than android Q one​
    It works perfect on TMobile maybe you did a dirty flash and didn't do a reset after installation
