200
Android Q Developer Preview 4 for OnePlus 7 Pro and 7
  1. H1561960043803
    Honeycomb Aug 19, 2019
    H1561960043803 , Aug 19, 2019 :
    drhide2020
    Rolled back to 9.5.11
    Why?
    -DP4 signal is sooooo bad, my google fi almost stopped working on it and keep disconnecting, even if connected the speed on 4G+ almost 56Kb
    -oneplus Pie gestures away better than the DP4 one, i have it on my Pixel 3 and i can say it is so bad, wishing oneplus will keep its gestures as it is much better than android Q one​
    like he said try factory reset after you install dp4. no, it's not perfect , but still cool. I came from an iPhone x( not proud) so the android Q gestures don't bug me. I'm a little upset that they copied apple , but oh well. anyway after the reset , only major problem I had was that phone calls constantly came out of bottom speaker, even when speaker phone wasn't on. I read that a hands free Bluetooth fixed this problem,you just use that. I went back to 9.511 for the phone issue.cause I have no Bluetooth headphones
    MFaisalT.89 and drhide2020 like this.
  2. vriesdejoop
    Ice Cream Sandwich Aug 19, 2019
    vriesdejoop , Aug 19, 2019 :
    JmcRepair33
    Rule number 1 don't ask for when something is coming out​
    why are you quoting me????
    I'm not asking anything....
  3. JmcRepair33
    JmcRepair33 , Aug 19, 2019 :
    That is correct phone calls in speaker mode if you don't use Bluetooth and to unlock only fingerprint doesn't work but does work for in app fingerprint to log in
    H1561960043803 likes this.
  4. JmcRepair33
    Sorry I didn't mean to quote you. Lol I thought I did a new one sorry lol my bad
    vriesdejoop likes this.
  5. H1561960043803
    hahahahaha. .. dirty flag.. [e]1f602[/e]. I know you meant flash..still funny
  6. siyaantu
    Eclair Aug 19, 2019
    siyaantu , Aug 19, 2019 :
    Android Q yüklersem bütün verilerim gider mi..
    Oxijen özellikleri gider mi
    Çift Facebook kullanırmıyım
    ACIL CEVAP LÜTFEN
  7. vriesdejoop
    ja dat denk ik ook niet of toch wel?
  8. H1561960043803
    joshuaabishek likes this.
  9. MFaisalT.89
    Cupcake Aug 19, 2019
    MFaisalT.89 , Aug 19, 2019 :
    yes I understand. I'm not suggesting that it could be the problem, I'm just saying that it's pretty annoying.
  10. GauravMajithia
    Donut Aug 20, 2019
    GauravMajithia , Aug 20, 2019 :
    Review for OnePlus7 (Not Pro)
    After 2 weeks of Usage
    Broken:
    1. Screen Cast
    2. Zen Mode or System Sleep (Leave Phone Locked for 4-5 hours and zen mode will remind you that you are using phone since 4 hours)
    3. Battery Backup (Probably due to Point 2)
    4. Gpay Works but Amazon Pay does not (looks like app compatibility issue)
    5. Horizon Lights
    6. Many Full screens apps / settings are wierd but works
    7. Night Mode does not work on Fingerprint Screen (If app is fingerprint enabled, when the fingerprint screen comes the Night mode is not seen, after authentication it goes back to night mode)
    Works:
    1. Everything else works
    2. Bluetooth Headset, Bluetooth Sound cast
    3. Gestures, Phone, Sensors, Sound, Dolby, Screen Rotation
    Volte Not tested, but would work I believe
    joydeep33.dey likes this.
  11. docnok63
    Ice Cream Sandwich Aug 20, 2019
    docnok63 , Aug 20, 2019 :
    I have the Pro model and casting to my NVIDIA SHIELD works 100%. Make sure the device you're trying to cast to and your phone are on the same network.
  12. GauravMajithia
    Donut Aug 20, 2019
    Yep they are.. Does not work.. I have another onePlus7 (not Pro) running Stable Oxygen OS and it works on it.
    docnok63 likes this.
  13. naikjeevan
    Froyo Aug 20, 2019
    naikjeevan , Aug 20, 2019 :
    I installed DP4 on my OP7 Pro it's amazing but still needs polishing, good work OP NEVER SETTLE [e]1f44d[/e].
    Things I liked,
    1. Camera app - awesome no more zoomed portraits, 2x zoom in nightscape mode & macro shot option.
    2. Notification panel customisation.
    3. All black theme (all apps except clock app)
    4. Alot of customisations like horizon lights, themes etc.
    5. File manager - cache cleaner is back & also junk file cleaner.
    6. Also like the digital well being feature.
    Things I didn't like,
    1. Guesture - swipe from side to go back is annoying at times, it's was difficult to swipe on curved screen. also causes accidental touches (Maybe because am not used to it). Home button flickers for some apps & on landscape mode it's at bottom, didn't like it.
    2. On home screen there is 2 plus signs at bottom left and right.
    3. Ambient screen clock keeps changing after some time of standby. I used digital it changes back to analogue.
    4. Slow WiFi & mobile data speed. Also network issues a few times.
    5. Few apps didn't open (like Netflix n few games) showed unable to open error.
    Moving back to pie, have to wait until the stable is launched.
  14. mariusmuntensky
    Eclair Aug 20, 2019
    mariusmuntensky , Aug 20, 2019 :
    Running DP4 on OP7 here. Calls sound fine on speaker and earpiece, bluetooth audio is great, louder and richer than it was on Pie. Camera has some fixes in the processing of images, battery life is ok, GPay works, Samsung Galaxy Fit does not work on it - Fit plugin crashes all the time.
    I have a weird artifact on my screen, like an icon that keeps appearing when I am outside (attached image).
    OK Google does not work
  15. vriesdejoop
    vriesdejoop , Aug 20, 2019 :
    The icon has been discussed here in the forum, search a couple pages back. Galaxy Fit is a setting on your phone, Its working fine on mine, no problems of the plugin crashing!
  16. mariusmuntensky
    Eclair Aug 20, 2019
    Tried pairing my galaxy fit 2019 band and it fails because the Galaxy Fit Plugin app keeps crashing. I tried to remove/install it back, no luck :(
    Regarding that icon, yep, found the answer...never ever thought of that :))
  17. JmcRepair33
    Honeycomb Aug 20, 2019
    JmcRepair33 , Aug 20, 2019 :
    is it Q compatible?
  18. Ajsat3801
    Gingerbread Aug 20, 2019
    Ajsat3801 , Aug 20, 2019 :
    I don't know if it's q compatible but I use a fit 2 pro with my phone with no problems other than an ocasional connection drops..
  19. JmcRepair33
    well im assuming the app is because fit keeps there stuff up to date. but some apps dont work 100 percent yet. i reccomend waiting a week till our dp5 and hold off on the fit for a week if you can so you dont have to flash back. do you have a spare phone for temporary for the fit?
  20. Nicks_Kothari
    Cupcake Aug 20, 2019
    VJK21 likes this.
