200
Android Q Developer Preview 4 for OnePlus 7 Pro and 7
  1. JmcRepair33
    Honeycomb Aug 20, 2019
    JmcRepair33 , Aug 20, 2019 :
    I'm not exactly sure go to the first couple post in this thread says something about 5g version
  2. JmcRepair33
    Yes I reported them though. Report those people please
  3. __aa_vi__
    Gingerbread Aug 20, 2019
    __aa_vi__ , Aug 20, 2019 :
    rename it and file extension should be or ends with (.zip) not (.rar)
  4. Z1564768169287
    Cupcake Aug 20, 2019
  5. Lokeshwar Reddy Muppidi
    Donut Aug 20, 2019
    JmcRepair33 likes this.
  6. Mrcgibb
    Mrcgibb , Aug 20, 2019 :
    It is named zip. I assume the software is not compatible with the 5g version so it won't install
  7. Nic2112
  8. Nic2112
    Nic2112 , Aug 20, 2019 :
    I think any forum will have questions answered multiple times because asking will always be quicker than searching.
    My comment about notifications was only related to the fact that the majority of posts now are what I call non productive. No fixes for issues, no new finding, just asking the same questions over and over.
    JmcRepair33 and H1561960043803 like this.
  9. JmcRepair33
    Dont mention OnePlus 6 in this forum its a bad word lol
    aakashmaji16 likes this.
  10. JmcRepair33
    I do agree on that... Everyone just needs to start helping out everyone out instead of repeating the same things and starting Rumors of new versions and so on.
  11. docnok63
    Ice Cream Sandwich Aug 20, 2019
    docnok63 , Aug 20, 2019 :
    You're the first 5G owner that has actually downloaded and posted the results. Most have just asked, "Is it compatible with 5G?" never to be seen again. If you're sure you downloaded the DP4 installer and not the reverting to Pie installer (i.e. there's no wipe in the file name), then there must be a system check done by the software upgrade software that prevents installing a wrong version for your device. A simple check would be for me to download the OP7 revert software and see if my Pro sees it. I'll report back.
  12. docnok63
    It's completely confirmed. My Pro doesn't see OP7 revert file, so you're correct; this version isn't compatible with the 5G model.
  13. JmcRepair33
    No it's not found to show to flash due to the 5g chip modem
  14. aburmrm
    Donut Aug 20, 2019
    mateusz91 likes this.
  15. H1561960043803
  16. aburmrm
    Donut Aug 20, 2019
  17. aburmrm
    Donut Aug 20, 2019
  18. docnok63
    C'mon man. Be realistic. The Software Upgrade software isn't that sophisticated. It probably looks a file names and sees that it's incompatible with your current device and doesn't show it. No modem chip differences are involved in Pro vs non-Pro variants which is what I just tested.
  19. H1561960043803
  20. H1561960043803
    Honeycomb Aug 21, 2019
    H1561960043803 , Aug 21, 2019 :
    alright. just tried the q beta one more time in the hopes that I didn't have the phone bug. I do. just waiting for the revert to download. sucks. I really want to use q. hopefully the phone bug is fixed next release
