201
Android Q Developer Preview 4 for OnePlus 7 Pro and 7
  1. Nic2112
    Ice Cream Sandwich Aug 21, 2019
    Nic2112 , Aug 21, 2019 :
    I did the same thing tonight because I messed with VoLTE and wasn't sure if I broke something. Figured since I have to do a wipe, might as well try Q.
    I'm not seeing the display glitches I saw before, phone is working as expected, knock on wood but it seems to work differently than the last time I tried Q
    H1561960043803 likes this.
  2. H1561960043803
    H1561960043803 , Aug 21, 2019 :
    lucky lol back to 9.5.11 I go...such a long process lol watch , dp5 will come out tomorrow... my luck lol
    mateusz91 and JmcRepair33 like this.
  3. Nic2112
    Same here, I'm not keeping it. I have a little one in daycare and if there was an emergency and they could not reach me because of phone issues, it would not go.well.
  4. JmcRepair33
    Honeycomb Aug 21, 2019
    JmcRepair33 , Aug 21, 2019 :
    Yes family first. If that is the issue keep it stable
  5. martinklaus
    Gingerbread Aug 21, 2019
    martinklaus , Aug 21, 2019 :
    I was hoping that Google will release Android Q this week, but the end of the week is getting closer [e]1f632[/e][e]1f632[/e][e]1f632[/e]. But if not this week than next ¯\_(ツ)_/¯
  6. G_Hari_Jayan_kfiw
    Cupcake Aug 21, 2019
  7. martinklaus
    I think you will find the solution on the first page.
  8. docnok63
    docnok63 , Aug 21, 2019 :
    Google already released DP6 on August 7th. It's now up to OnePlus to apply OOS to that build and release their next DP/first Open Beta. We guess this on or after next Friday.
  9. martinklaus
    docnok63
    Google already released DP6 on August 7th. It's now up to OnePlus to apply OOS to that build and release their next DP/first Open Beta. We guess this on or after next Friday.​
    t think this is the last DP the next release will be an open beta based on final Android Q. on which Android beta version the DP4 is based?
  10. docnok63
    If you look at the bottom line I quoted from the OP, the next build will be called OnePlus's first Open Beta for Q. It will be based on Google's DP6. This build is based on Google's DP5.
    JmcRepair33 likes this.
  11. Ken_Brownstone
    Froyo Aug 21, 2019
    JmcRepair33 and Smokee464 like this.
  12. Manju K Gowda
    Donut Aug 21, 2019
  13. docnok63
    Hide option? You can just disable the app or remove the directory from system/proc-app if you're rooted
  14. oneshotaz
    Froyo Aug 21, 2019
    oneshotaz , Aug 21, 2019 :
    I wish we can have more customization options, like native theming or lock screen changes
  15. Technical Rudra
    Technical Rudra , Aug 21, 2019 :
    I am install Android Q beta version for OnePlus 7 but Android pie Logo not changed only Number change 9 to 10...
  16. Smokee464
    Smokee464 , Aug 21, 2019 :
    it's ok)))
  17. DJSubterrain
    DJSubterrain , Aug 21, 2019 :
    Anyone else having problems with https://messages.google.com losing connection to the messages app when the phone is asleep? I've turned off battery optimisation for the app and now turned it off altogether. Page only links up when I wake the phone and open the messages app.
  18. docnok63
    Yes, that's how it is for this build (and all of our previous builds.) Even our Easter Egg is for Pie. Only the Essential phone has the new Easter Egg, but they are one Google's DP6
    EDIT: I forgot, there is ONE sign that we're on Q. They symbol has changed when you connect via USB
  19. fonix232
    Eclair Aug 21, 2019
    fonix232 , Aug 21, 2019 :
    I wouldn't expect the final Q drop until next weekend, or possibly around 2nd-4th September.
    I really hope for this Friday. OOS doesn't have that many changes to Q yet to make it hard to port, and should be relatively straightforward to do the release. In fact I'd be much happier if OP decided to make the Developer Preview a bit more buggy, but with weekly updates instead of ~monthly. Hopefully with the R preview next year, they'll adopt this method (pull in Google's DP as soon as possible, release with bugs, then release weekly bugfixes until next Google DP).
  20. Smokee464
