157
Android Q Developer Preview 4 for OnePlus 7 Pro and 7
  1. docnok63 Gingerbread Aug 6, 2019
    Kuma76 and Deemigs like this.
  2. Q1529908435633 Gingerbread Aug 6, 2019
  3. Q1529908435633 Gingerbread Aug 6, 2019
    Q1529908435633, Aug 6, 2019 :
    BTW bro is dark mode available in this DP update ?
  4. docnok63 Gingerbread Aug 6, 2019
    Q1529908435633 likes this.
  5. wiswis Cupcake Aug 6, 2019
    wiswis, Aug 6, 2019 :
    so using the zip you can flash dp4 from pie with no wipe, but if you want to revert back to pie a full wipe will be done. Is this correct?
  6. JoseReyes69 Gingerbread Aug 6, 2019
    JoseReyes69, Aug 6, 2019 :
    Correct
  7. docnok63 Gingerbread Aug 6, 2019
    docnok63, Aug 6, 2019 :
    Yes
  8. E1564718011740 Donut Aug 6, 2019
    E1564718011740, Aug 6, 2019 :
    Only The First Dev Preview Have I Been Able to Use Data, none of these others register my network and the unlock tool doesn't seem to work
  9. docnok63 Gingerbread Aug 6, 2019
  10. E1564718011740 Donut Aug 6, 2019
  11. UndeadAD Eclair Aug 6, 2019
    UndeadAD, Aug 6, 2019 :
    so I can unlock it by the tool
  12. docnok63 Gingerbread Aug 6, 2019
    If you're talking about the Oxygen Updater app, make sure you have Advanced Mode toggled on and then select Android Q Developer Preview at the top under Update method
  13. UndeadAD Eclair Aug 6, 2019
    is there any way of getting this to work without unlocking it I'm already on the international firmware
  14. jejigeorge1 Donut Aug 6, 2019
    jejigeorge1, Aug 6, 2019 :
    It will work if you turn on the ambient display for new notification. but can't customize the horizon light.
  15. Georgeoneplus7pro Gingerbread Aug 6, 2019
  16. E1564718011740 Donut Aug 6, 2019
    Ohh? no I didn't know about the app at all
  17. docnok63 Gingerbread Aug 6, 2019
  18. wiswis Cupcake Aug 6, 2019
  19. E1564718011740 Donut Aug 6, 2019
    I just removed .jar and it worked fine
  20. L1541501419579 Eclair Aug 6, 2019
