200
Android Q Developer Preview 4 for OnePlus 7 Pro and 7
  1. TheNet
    Cupcake Aug 23, 2019
    TheNet , Aug 23, 2019 :
    Thank you, will try it.
  2. Nic2112
    Honeycomb Aug 23, 2019
    Nic2112 , Aug 23, 2019 :
    I didn't need to do that but I also did a factory reset after the upgrade so maybe that's another way to not have that issue
  3. H1561960043803
    H1561960043803 , Aug 23, 2019 :
    ok all set up annnnd nope. tried the modified Google dialer and calls still come through the speaker. I hope they fix this in next version [e]1f61e[/e] oh well back to 9.5.11
    docnok63 likes this.
  4. docnok63
    Ice Cream Sandwich Aug 23, 2019
    docnok63 , Aug 23, 2019 :
    Can you link for me and others which version you used?
  5. TheNet
    Possible. It is disabled in P by default. I didn't do factory reset when I got to Q. But banking apps not working tho.
  6. H1561960043803
  7. docnok63
    Are you rooted and not passing SafetyNet?
  8. H1561960043803
    I1559961085303 and docnok63 like this.
  9. docnok63
    H1561960043803 likes this.
  10. H1561960043803
    if you know of another version, I'd be happy to test it
  11. H1561960043803
  12. docnok63
  13. Nic2112
    Also odd, I use two banking aps here in Canada as well as Google pay and they all work.
  14. Nic2112
    I think I tried it even if I didn't have the earpiece issue. couldn't find how to pick the sim card to use though, I think it's meant for single sim.
  15. docnok63
    Ya, I just noticed that the newest one that I linked was based on Dialer v30 and @H1561960043803 linked based on Dialer v36. Stick with what works ;)
    EDIT: After looking at the filename, it's not even a modified version. It's just the Dialer straight from Google via Apkmirror. It's not even the right DPI for our phone (default is 560...use nodpi versions from that site.)
    https://www.apkmirror.com/apk/google-inc/google-phone/
    EDIT 2: So someone on 10 should give this one a go.
  16. H1561960043803
    my bad I thoughts that where everyone got their dialers. it has been modified because normally Google dialer doesn't work at all. says device is unsupported. I'm not smart enough to know how or what was modified lol that's why we have smart ppl like you lol
  17. H1561960043803
    trying it now
  18. docnok63
    Nah, my bad. It's definitely been modified because the one I linked above under EDIT 2 doesn't install on 9.5.11 and your modified v36 one says unsupported device like you just said. Soooooooo, now we have a very recently modified version working. Time to hunt for a thread with the modified version of the newest build.
  19. docnok63
  20. H1561960043803
    ok. downloaded both of the v 37 ones the first one calls still comes the speakerphone when speaker phone is not on. haven't tested the second yet. confirmed that you don't get the device unsupported message on 10. still even with getting that message, I was still able to use the dialer on 9.5.11
