202
Android Q Developer Preview 4 for OnePlus 7 Pro and 7
  1. Sh4pp0
    Froyo Aug 30, 2019
    Sh4pp0 , Aug 30, 2019 :
    Follow this tutorial about getting the app itself to work.
    Then you have to enable the actual lens swap method in the settings by changing it to "long press".
    After that, you can swap lenses by long pressing the button that usually changes to your front facing camera and back. You can only swap between a set of two cameras tho. It's either normal/ wide angle or normal/ tele. The default is normal/ tele. To change the second option to wide angle, you have to enable the option "Enabled Camera ID3" in the settings.
    Ajsat3801 likes this.
  2. docnok63
    Jelly Bean Aug 30, 2019
    docnok63 , Aug 30, 2019 :
    I installed DP4 for the fifth time this morning. I had a new app constantly FC'ing on boot. Thankfully a reboot fixed it. I deleted RiCE mod (not compatible with 10 yet) and reinstalled Viper4Android. Google Assistant works, so that makes 3/5 installs. I updated to Android Auto 4.6 and it still doesn't appear in the app drawer. I also tried moving it to system/priv-app without any luck. There's definitely a framework issue going on. I immediately checked OxygenUpdater and then VPN'd to several countries trying to trigger an OTA to no avail. Oh well, at least I'm enjoying the new TOOL with Viper!!!
    Welcome to the thread! I haven't used Snapchat in ages as most of the people I followed went to Instagram. The only information I could find on the internet was that it definitely uses camera1 api. Aside from that, the only help I can give you is verifying that the back camera is Level 3 and the front is full camera2 api capable. Screens below.
    Yes, this is normal
    Sh4pp0, H1561960043803 and Ajsat3801 like this.
  3. Sh4pp0
    Froyo Aug 30, 2019
    Thank you!
    Yeah, that's what I thought. I couldn't find anything else either :/ Also, Snapchat has been refusing to talk about it, even when they came out with that big update a while ago and people started freaking out, thinking that must be it. But it wasn't....
    Thanks for the info about the cameras, though. That's good to know at least.
    I'm just wondering what all of this might have to do with DP4? Afaik it's Snapchats implementation that comes into play here, isn't it? How would a system update change the way that the app interacts with the camera? It's also not a Snapchat update that has been triggered by updating to DP4 or anything like that. It's a night and day difference taking snaps on pie vs. 10 and this intrigues me a lot. Even the filters and whatever you throw at it in terms of "editing" look way better imo. Weird.
  4. Nic2112
    Ice Cream Sandwich Aug 30, 2019
    Nic2112 , Aug 30, 2019 :
    Looks like this thread is no longer pinned. could be a mistake though.
  5. Sh4pp0
    Froyo Aug 30, 2019
    Wasn't that already discussed a few pages back? I thought it hasn't been pinned for a while.
  6. Nic2112
    It was pinned, then not, then pinned back, then not anymore.
  7. Sh4pp0
    Froyo Aug 30, 2019
    Oh well...
  8. Ajsat3801
    Gingerbread Aug 30, 2019
  9. akks
    akks , Aug 30, 2019 :
    Some lady mod is the culprit:D
  10. TheKempter
    Cupcake Aug 30, 2019
    TheKempter , Aug 30, 2019 :
    So maybe I've missed the memo but since I've installed the dp4 on my 7pro I've had severe problems with my gps as it's not getting a fix or taking several minutes to find one if at all. most of the time I have only the accuracy from mobile data location. Have any of you faced the same problem and how'd you deal with it?
  11. Sh4pp0
    Froyo Aug 30, 2019
    I believe some people even reverted back to pie for that reason. Unfortunately, I don't think anybody mentioned a fix. Luckily, mine seems to be doing fine.
  12. bandit1976
    bandit1976 , Aug 30, 2019 :
    Hi guys,
    I'm right now on 9.5.11 and would like to go to dp4. Can I flash it thru the updater?
    Thanks
  13. Colday_96
    Froyo Aug 30, 2019
    Colday_96 , Aug 30, 2019 :
    I think you first need to roll back to 9.5.10 or earlier to flash dp4.Once you have done that, you'll be able to flash it through the updater.
    bandit1976 likes this.
  14. bandit1976
  15. H1561960043803
    H1561960043803 , Aug 30, 2019 :
    bandit1976
    What would happen if I download dp4 and flash it?
    I've flashed dp4 over 9.5.11 a few times through the local upgrade and have not had problems that aren't already known. do a factory reset after you get it installed to decrease your chances of issues. I have never updated through the oxygen updater though.... also doc knows of a rooted method to update through xda developers I believe.
  16. bandit1976
  17. TheKempter
    so I guess we'll just have to wait and hope that OP fixes that issue with the upcoming open beta...
    Sh4pp0 likes this.
  18. H1561960043803
    are you on international firmware, or gm1915?
  19. bandit1976
  20. H1561960043803
    I believe you should be good to go, but let someone smarter than me confirm it before you do it . I have TMobile version converted to international.
    docnok63 and bandit1976 like this.
