202
Android Q Developer Preview 4 for OnePlus 7 Pro and 7
  1. Pavan0007
    Cupcake Aug 6, 2019
    Pavan0007 , Aug 6, 2019 :
    once reboot the device and try again
  2. nagpalkapil
    Donut Aug 6, 2019
    nagpalkapil , Aug 6, 2019 :
    [e]1f44d[/e]
    Vaibhav_sinha likes this.
  3. U1564374217246
    Cupcake Aug 6, 2019
    U1564374217246 , Aug 6, 2019 :
    How to solve the black area below the input method
    I hope to solve this problem as soon as possible, thank you。
  4. joydeep33.dey
    Eclair Aug 6, 2019
  5. U1564374217246
    Cupcake Aug 6, 2019
  6. cssrc1974
    Jelly Bean Aug 6, 2019
    cssrc1974 , Aug 6, 2019 :
    why my one plus pro is not recognising the local upgrade package even if it is kept in the root folder ( internal storage) as an independent file and not inside a folder. why??
  7. G_Divyesh_Gondaliya_ShSv
    Cupcake Aug 6, 2019
  8. cssrc1974
    DP 4 installed . no loss of data at all. so far all good. both volte (Jio and idea working)
  9. R_d_M
    Gingerbread Aug 6, 2019
    R_d_M , Aug 6, 2019 :
    Only bug for me until now.
    Sometimes notification sounds goes, but there is no notification
  10. ashutoshsingh577
    Eclair Aug 6, 2019
  11. guruprasaddp
    Froyo Aug 6, 2019
    guruprasaddp , Aug 6, 2019 :
    Presently I am in 9.11 version stable can I install the dp4 on my phone... Help me any one
  12. guruprasaddp
    Froyo Aug 6, 2019
    Better to take backup and wipe the data. After installing Q new thing will happen
  13. truelectro
    Eclair Aug 6, 2019
    truelectro , Aug 6, 2019 :
    Make sure "Disable Bluetooth A2dp hardware offload" is turned off in Developer options
    Riz157 and Vaibhav_sinha like this.
  14. guruprasaddp
    Froyo Aug 6, 2019
    Can u tell me how can I install from 9.5. 11 to dp4
  15. cssrc1974
    download dp 4. take the file and paste in the main storage. not inside any other folder. then go into system settings and select local upgrade..
    before that back up and save all photos etc. most likely it won't be deleted but still don't take a chance. mine was intact after I upgraded.
    guruprasad_dp999 likes this.
  16. nagpalkapil
    Donut Aug 6, 2019
    Is your Bluetooth audio working?
  17. docnok63
    docnok63 , Aug 6, 2019 :
    You have to remove the .jar at the end of the file name and the phone will see the file. MUST be .zip at the end only.
    Data will remain
    Yes. I literally just did this within the last 30 minutes. Just download the file and do local upgrade or flash via TWRP. Reinstall TWRP right after if you do it this method (and Magisk if you use.)
    I just upgraded from 9.5.11 to DP4 for the second time and my Assistant works again for the second time on DP4. The last time it broke, I literally just woke up and it no longer worked, so I'll see if it sticks with the new Google Play Store, Services, and App apks but I'm HAPPY for now!!! :D
    Also, thanks to this post I got V4A working on Q!!!! I had to install the driver twice (which reboot twice) and enable compatibility mode like he said, but all (even DDC and convolver) works after that!!!!!! (I didn't install AML.) I LOVE V4A!!!!!
  18. cssrc1974
    it's already done. thanks for ur support and help.
  19. RandyManLB
    RandyManLB , Aug 6, 2019 :
    Anyone having issues with IPv6? Ping tests failing. Worked fine on Android P. On AT&T.
  20. C1565082861903
    Donut Aug 6, 2019
    ran.777 and RandyManLB like this.
