201
Android Q Developer Preview 4 for OnePlus 7 Pro and 7
  1. docnok63
    Jelly Bean Aug 31, 2019
    docnok63 , Aug 31, 2019 :
    There's a directory on your internal called .Ota. The file will be in there until you reboot and then it will vanish
    If you haven't rebooted, please look in the directory above and upload that file to you Google Drive
  2. kammingwai
    Eclair Aug 31, 2019
    kammingwai , Aug 31, 2019 :
    uploading
    docnok63 likes this.
  3. docnok63
  4. M1559834330967
    Eclair Aug 31, 2019
  5. Nic2112
    Ice Cream Sandwich Aug 31, 2019
    Nic2112 , Aug 31, 2019 :
    It might since this will be a 2 gig file.
  6. kammingwai
    Eclair Aug 31, 2019
    I just found that the file is in the . Ota folder
  7. Nic2112
    Oxygen updater had an "Update available" banner, but it's an update to the app, not the OS :)
  8. M1559834330967
    Eclair Aug 31, 2019
    M1559834330967 , Aug 31, 2019 :
    yeah was fooled too
  9. Marcstang04
    Gingerbread Aug 31, 2019
  10. docnok63
    If his bootloader is unlocked and he gets the fill zip, then yes with old TWRP
    Is your bootloader unlocked? I think it is
  11. M1559834330967
    Eclair Aug 31, 2019
    how is the upload going , hahha
  12. kammingwai
    Eclair Aug 31, 2019
    the zip is 2.15 GB
    so I think it's the full zip
    J1557410854041 and docnok63 like this.
  13. docnok63
    Thanks for confirming. It's so hard to type in here and keep switching VPN sites to try to trigger :p
  14. kammingwai
    Eclair Aug 31, 2019
  15. docnok63
    Don't apologize. You'll be doing the rest of us a HUGE favor
  16. M1559834330967
    Eclair Aug 31, 2019
    it's okay man ! Thanks for uploading
  17. Ajsat3801
  18. Ravitejanayudu
    Froyo Aug 31, 2019
  19. Ajsat3801
  20. Ravitejanayudu
    Froyo Aug 31, 2019
    Ravitejanayudu , Aug 31, 2019 :
    I m in 9.5.8 version version I want to install dp5 is there any data loose
