242
Android Q Developer Preview 5 for OnePlus 7 Pro and 7
  1. Manu J.
    OxygenOS Product Staff Member Aug 31, 2019
    Manu J. , Aug 31, 2019 :
    OnePlus 7 Series gets Android Q Developer Preview 5!
    As the name suggests, this build of Android Q is best suited for developers and early adopters. As it is still in an early stage of development, we do not recommend flashing this ROM if you have little or no experience in software development or flashing custom ROMs. Proceed at your own risk!
    Caution: You should understand the risk of BRICKING your phone, read the instructions carefully and be 100% sure of what you are doing, and please always backup your important data before flashing.
    IMPORTANT: Please backup your data before upgrade!!!
    New Changes:
    • System functions improvement
    • System stability improvement
    • Added the OnePlus full-screen gestures
    • Based on Google Android 10 Beta6
    • For DP4 users, you can upgrade via online OTA
    • From DP5, you can upgrade system via OTA to Open Beta
    Known Issues
    • Application compatibility problems
    • Compatibility issues with Google Pay
    • Low probability of system lag and stability issues
    Please note: This instruction is only for OnePlus 7/7 Pro, and please make sure the battery level is above 30% and minimum 3GB of available storage space.
    MP version = Stable official version
    DP version = Developer Preview version
    MP to DP upgrade guide—via Local OTA Update
    Note: This upgrade method will erase all the contents of the phone, please be sure to backup first.
    1. Download the latest ROM upgrade zip package from the specified server.
    2. Copy the ROM upgrade package to the phone storage.
    3. Go to Settings -> System -> System Updates -> Click top right icon -> Local upgrade -> Click on the corresponding installation package -> upgrade -> System upgrade completed to 100%.
    4. After the upgrade is complete, click Restart.
    5. The phone will boot into recovery mode to format user data, it will reboot again after formatting.
    6. Update successful.
    DP to MP rollback guide - via Local OTA update
    2. Copy the Rollback package to the phone storage.
    Ready to get started on the Android Q Beta?
    Want to go back to Android Pie? Download the Rollback package from the links below:
    As always, please share your feedback through https://forums.oneplus.com/feedback/. For more information on submitting bugs or suggestions please refer to How to report a bug and feel free to share your product suggestions via the Community app.
    Never Settle.
  2. Nic2112
    Ice Cream Sandwich Aug 31, 2019
    F1542464380939, Ven96, Sh4pp0 and 2 others like this.
  3. docnok63
    Jelly Bean Aug 31, 2019
    Sh4pp0 and noquarter like this.
  4. Colday_96
    Froyo Aug 31, 2019
    Colday_96 , Aug 31, 2019 :
    thanks a lot for the release!
    The future is looking really bright for the OnePlus 7! ^^
  5. q784400487
    Froyo Aug 31, 2019
  6. Nic2112
    AlexVenski and Sh4pp0 like this.
  7. H1561960043803
    Sh4pp0 likes this.
  8. IRhyiku
    Honeycomb Aug 31, 2019
    IRhyiku , Aug 31, 2019 :
    "OnePlus 7 Series gets Android Q"
    So I guess the 5G version isn't part of the 7 series.
  9. 7r.st1
    Froyo Aug 31, 2019
  10. TurboCarnage
    Donut Aug 31, 2019
  11. Nic2112
    Nic2112 , Aug 31, 2019 :
    Download with a browser, or better yet, with a computer and then copy the file.
    E1565805199217 and 7r.st1 like this.
  12. G_DepressiveDepressions
    Donut Aug 31, 2019
    Jessebarto and USBA JasonB like this.
  13. meatandy
    Oreo Aug 31, 2019
  14. H1561960043803
    H1561960043803 , Aug 31, 2019 :
    can do the same trick as last time if get .jar at the end, and just rename it, deleting the jar part, correct?
    hsntareq and Sritejkadiveti like this.
  15. q784400487
    Froyo Aug 31, 2019
    q784400487 , Aug 31, 2019 :
    Maybe just delete '.jar' part?
  16. 7r.st1
    Froyo Aug 31, 2019
    7r.st1 , Aug 31, 2019 :
    Still a .jar file, but it somehow worked to rename the file to "...zip" instead of "...zip.jar"
    RainyMoonShadow and Nelfym like this.
  17. 7r.st1
    Froyo Aug 31, 2019
    yeah, worked[e]1f44d[/e]
  18. Deactivated User
    Aug 31, 2019
    hsntareq and USBA JasonB like this.
  19. akks
    Lollipop Aug 31, 2019
  20. sechinov
    D1567619263582 likes this.
