242
Android Q Developer Preview 5 for OnePlus 7 Pro and 7
  1. Ajsat3801
    Gingerbread Sep 2, 2019
    Ajsat3801 , Sep 2, 2019 :
    J1557410854041
    tomorrow is 3rd September i hope official Android 10 beta 1 release after release Google release Android 10...​
    don't keep high expectations though.... It has just been 2 days since dp5 released...
    MarcoV1+, awes0me1 and crisjohn02 like this.
  2. techfreak243
    Froyo Sep 2, 2019
    techfreak243 , Sep 2, 2019 :
    I'm getting used to using them now with my poetic affinity case but the area is to small for activation. I'm not even sure if I'm gonna go to. full Android 10 official stock release if it's gonna be like this
  3. crisjohn02
    Froyo Sep 2, 2019
    crisjohn02 , Sep 2, 2019 :
    true. Especially the devs busy fixing bugs from dp 5 or they can completely ignore it and work on the official release for the open beta so they won't get behind
    Ajsat3801 likes this.
  4. Ajsat3801
    we can always use the classic three button navigation.... btw I'm getting used to this....
  5. jasperjunnu
    Froyo Sep 2, 2019
    jasperjunnu , Sep 2, 2019 :
    just rename .zip.jar file to .zip and you are good to go.. best of luck
    H1561960043803 likes this.
  6. F_Sanjay_Yadav_CQcK
    Cupcake Sep 2, 2019
  7. techfreak243
    Froyo Sep 2, 2019
    yeah. but I like the two button navigation. I have been used to that for awhile. the three button navigation seems archaic to me lol
  8. ZMansour
    Donut Sep 2, 2019
  9. crisjohn02
    Froyo Sep 2, 2019
    in the first page Sir :) might as well read before downloading so you won't regret
  10. DJSubterrain
    Ice Cream Sandwich Sep 2, 2019
  11. ramchalamkr
    Donut Sep 2, 2019
    ramchalamkr , Sep 2, 2019 :
    is anyone having issues with ambient display? when I get a new notification from certain messenger apps, the screen doesn't turn on automatically. I had turned everything on for the notifications. not sure if it's an isolated issue.
  12. DJSubterrain
    DJSubterrain , Sep 2, 2019 :
    Hmmm, Our office is one of those prefab metal buildings though, it's never been the best for data reception, I'll keep an eye on it then. Thanks.
  13. pavanpv9
    Froyo Sep 2, 2019
  14. F_Shashi_Gowda_AifX
  15. Dresa91
    User of the Year 2016; Most Active User 2020 Sep 2, 2019
    Dresa91 , Sep 2, 2019 :
    read the first post
  16. dinbandhukumar
    dinbandhukumar , Sep 2, 2019 :
    all data is as it is. no data was wiped . all the application works so far perfectly. u can upgrade it.
    G_Pavan_P_aoMh likes this.
  17. dinbandhukumar
    u need to download the stable version and u can downgrade it through local upgrade options from system update.
  18. Zvoni
    Honeycomb Sep 2, 2019
    Zvoni , Sep 2, 2019 :
    I don't have much experience and have a question: if i upgrade to this beta version and the stable one comes out, do i have to downgrade or is it gonna be a normal update without wiping my data?
  19. F_Shashi_Gowda_AifX
    F_Shashi_Gowda_AifX , Sep 2, 2019 :
    I have the same doubt....
    please answer if anyone knows
  20. H1561960043803
    H1561960043803 , Sep 2, 2019 :
    really. this has been answered so many times . the answer is when OnePlus releases it.
