Working android setup bug
  1. arvindhprasadh
    Cupcake Nov 8, 2018
    arvindhprasadh , Nov 8, 2018 :
    Android set up notification always displays in the screen and if I touch that notification the image which I posted gets displayed.
  2. stijnonlijn
    Ice Cream Sandwich Nov 8, 2018
    arvindhprasadh likes this.
  3. stijnonlijn
  4. arvindhprasadh
    Cupcake Nov 8, 2018
    I restarted my mobile but again the notification bar is on what to do now..?
  5. stijnonlijn
    stijnonlijn , Nov 8, 2018 :
    Did you try my suggestion in the listed thread?
    1. turn off mobile data.
    2. Turn on Wi-Fi and connect to the internet
    3. restart the device
  6. arvindhprasadh
    Cupcake Nov 8, 2018
    yes I tried this one it worked but after restarting same problem occurs
  7. arvindhprasadh
    Cupcake Nov 8, 2018
    give some other way to solve this
  8. Gav_W86
    Moderator Moderator Nov 8, 2018
    Gav_W86 , Nov 8, 2018 :
    try:
    Boot the phone into recovery mode and clear the cache.
    1. Power off phone.
    2. Power on phone whilst holding down the volume down button (this takes slightly longer to react than you would expect and after the initial splash screen goes blank for a slightly un-nerving amount of time. But just wait).
    3. Enter the PIN/Password you use to unlock the phone when prompted.
    4. Choose a language.
    5. Choose "Wipe data and cache" (don't worry this is only a path to a submenu, it won't delete your data).
    6. Choose "Wipe cache" (IMPORTANT - MAKE SURE YOU DON'T TAP ERASE EVERYTHING).
    7. It will confirm that you have selected clear cache and ask you to say YES.
    8. When it says success choose "Reboot"
  9. arvindhprasadh
    Cupcake Nov 8, 2018
    I tried this too but didn't work
  10. mohainutheen
    Cupcake Nov 9, 2018
    mohainutheen , Nov 9, 2018 :
    did not work all the apps in playstore also updated manully and wiped the cache data in secure mode ,the problem does not solved ,kindly give me some solution for this matter
  11. SiddarthCR
    Eclair Nov 9, 2018
    mohainutheen likes this.
