3
Android System consuming too much data
  1. jatink007
    Gingerbread Jun 9, 2017
    jatink007 , Jun 9, 2017 :
    Hi Guys,
    Every night I turn off my WiFi before sleep. Morning when I wake up and turn on the WiFi, I see a constant upload of data at about 100kbps that happens. Along with that upload, the phone starts to heat up. Has anyone observed this? I see that Android system is having a lot of data usage and there are a lot of OP processes in the list.
    I am on Beta 17, OP3.
    Just want to know is the data upload going to Google or OP?
  2. bpwest80
    KitKat Jun 9, 2017
    bpwest80 , Jun 9, 2017 :
    I'm on beta 17 and I've noticed the Android system using more battery when I'm on LTE. It's fine on WiFi. I do see the, almost constant, upload of data you're talking about when I'm on WiFi. I noticed it because I use internet speed meter. Even with the phone laying still not being used, the internet speed meter shows data moving. I figure it's Google Play Services backing up data. Anyways, I have more battery drain and wake locks when I'm on LTE. I've started using advanced battery optimization while on LTE and that seems to help. On WiFi I don't really have any trouble.
  3. jatink007
    my concern is about the data upload. It anyways consumes a lot of battery. what exact settings you use?
  4. mikica023
    Honeycomb Jun 9, 2017
    mikica023 , Jun 9, 2017 :
    Same , android system eats up the battery on mobile data, compared to WiFi. On WiFi it's ok.
    bpwest80 likes this.
  5. bpwest80
    KitKat Jun 9, 2017
    Try advanced battery optimization when on LTE. It's helped me out.
    mikica023 likes this.
  6. Conwear
    Cupcake Jun 9, 2017
  7. saifalikhan247
    Donut Jun 9, 2017
  8. Spelt
    Ice Cream Sandwich Jun 9, 2017
    Spelt , Jun 9, 2017 :
    The symptoms you described can also be malware on your phone. Data being used in the background even when off? Phone heats up. Just an FYI. Especially the upload is suspect. You might check it.
  9. bpwest80
    KitKat Jun 9, 2017
    Doubt it's Malware. I know it's not in my case. It's Google Play Services backing up data. It only happens on WiFi and I have Google backup turned on. Not Malware for me.
  10. G_Rajun_Doal_Ieis
    Honeycomb Jun 10, 2017
  11. vickyss.jpr
    Gingerbread Jun 10, 2017
    vickyss.jpr , Jun 10, 2017 :
    Here is a solution :
    Go to Google Play services application and clear its data and cache.
  12. jatink007
    jatink007 , Jun 10, 2017 :
    guys you guys are confusing Android system with play services. I have issue with Android system, the data upload is 1.6GB and for play services it's 98mb.
    also how to enable battery optimisation for LTE only?
  13. bpwest80
    KitKat Jun 10, 2017
    bpwest80 , Jun 10, 2017 :
    You can't enable it for LTE only. You just have to go in and turn it on when you're on LTE and then turn it off when you're not. You may want to check and force close the User Feedback app if it's not already stopped. I been keeping it force closed and it's helped my battery. It's been taking a oem log in the background on occasion. I keep getting a oem log file in my internal storage. Go check and see if you have an oem log in your file manager. I did, but since I been keeping the User Feedback app force closed I've not had another oem log file in my internal storage. You'll have to force close it each time you switch from LTE to WiFi though because it starts itself back each time you switch.
    jatink007 likes this.
  14. jatink007
    I have seen the logs and I remember I had cleaned them up. I use greenify to kill apps. I think I will disable it if possible.
  15. jatink007
    nope, can't disable it. Also what is the harm with advanced optimisation enabled on WiFi?
  16. bpwest80
    KitKat Jun 10, 2017
    I think if you'll keep the User Feedback app force closed each time you switch from LTE to WiFi it'll help your battery life and it'll stop those oem logs from showing up. Once you force close it, it'll stay force closed until you switch from LTE to WiFi or WiFi to LTE, then it'll restart. It's a pain but it really does help with battery life.
  17. bpwest80
    KitKat Jun 10, 2017
    You can't disable the User Feedback app. You can only force close it.
  18. jatink007
    That's weird. It should not turn on if it's forced. But then again it's a system app. Who knows what code was written to enable it
  19. jatink007
    what about advanced optimisation? Y not to keep it on on wifi
  20. bpwest80
    KitKat Jun 10, 2017
    There is no harm, you just may miss some notifications. I don't use advanced battery optimization on WiFi because I don't need to and honestly since I've been force closing the User Feedback app I've not been using it much on LTE. Before you try advanced optimization, try just keeping the User Feedback app force closed.
