24
[Submitted] Android System Handling Theme Notification
  1. gwjansen
    Gingerbread Feb 20, 2020
    gwjansen , Feb 20, 2020 :
    It will not get resolved magically - we need to wait for the next update. The issue has been reported to OP meanwhile so they are aware.
    #41
    iompatel likes this.
  2. KawaiiBit
    Cupcake Feb 21, 2020
  3. gwjansen
    Gingerbread Feb 22, 2020
    #43
  4. KawaiiBit
    Cupcake Feb 23, 2020
    KawaiiBit , via OnePlus 6T , Feb 23, 2020 :
    Nope. It doesn't seem to trigger only when updating apps.
    #44
  5. gwjansen
    Gingerbread Feb 23, 2020
    gwjansen , Feb 23, 2020 :
    Ok, then can you reply with when it's triggered as well? Installing triggers it as well where uninstalling does not. Maybe it's linked to the selected theme. Which theme do you have and have you modified it?
    #45
  6. KawaiiBit
    Well I would if I knew. There was no clear pattern that I noticed. Theme is set to nuanced dark and I changed accent color, shape and icon pack.
    #46
  7. I1543677598521
    Donut Feb 24, 2020
    #47
  8. jalfaenger
    Cupcake Feb 24, 2020
    #48
  9. Shankark98
    Cupcake Feb 27, 2020
    #49
  10. Rynorak
    Froyo Feb 29, 2020
    Rynorak , Feb 29, 2020 :
    I'm getting this too. UK. I don't want notified of this! I'm on 10.3.2 so I guess they haven't fixed this yet. Why are OnePlus so buggy? My phone will just go to lock screen on its own at random too. I was planning on getting the 8 pro but I'm having my doubts now.
    #50
    Avinash_Ch likes this.
  11. wmeyers
    Cupcake Mar 4, 2020
    #51
  12. brijeshvpatel
    Cupcake Mar 4, 2020
    #52
  13. gwjansen
    Gingerbread Mar 5, 2020
    gwjansen , Mar 5, 2020 :
    It is not a fraud - it is just a system message. You cannot disable system messages. The only issue imho is that the op handling theme function is logging / sending a system message which it shouldn't.
    #53
  14. tr1234567
    Cupcake Mar 6, 2020
    tr1234567 , Mar 6, 2020 :
    I found the solution Press long on top of the notification go to Settings press silent notification as pictured
    #54
    gwjansen likes this.
  15. gwjansen
    Gingerbread Mar 7, 2020
    gwjansen , Mar 7, 2020 :
    You cannot disable system notifications. But you can keep the FG item pressed and then you can disable only that notification / silence it. It is working! I just updated all apps and got no popups :)
    So first disable the notification dot, then keep the FG item pressed.
    #55
  16. gwjansen
    #56
  17. Avinash_Ch
    Cupcake Mar 10, 2020
    Avinash_Ch , via OnePlus 6T , Mar 10, 2020 :
    Same problem, just updated to 10.3.2 and the phone restarted, after that the notification triggered like 10-15 times continuously. Please reply me with any proper solution.
    And i am getting battery backup phone heating issues.
    #57
  18. zelendel
    Donut Mar 11, 2020
    zelendel , Mar 11, 2020 :
    This is a very big issue and I am hoping one plus fixes so I dont have to fix it myself with a custom rom. Maybe the team just doesnt know how to fix it. They are still rookies to the coding game (you can tell that just by looking at the software)
    #58
  19. gwjansen
    Gingerbread Mar 14, 2020
    gwjansen , Mar 14, 2020 :
    see the screenshots above, you can disable just that annoying notification. it works perfectly for me.
    #59
  20. rubenmejiac
    Cupcake Apr 2, 2020
    #60
