2
android system web view has got disabled and can't enable it.
  1. G_Vispi_Edibam_bqlo Cupcake Feb 9, 2017
  2. toastytoast1234 Marshmallow Feb 9, 2017
    toastytoast1234, Feb 9, 2017 :
    Damn, I wish there had been at least one thread about this before so that you could research your options.
    ronnie__shah, Vedant620 and [GG] like this.
  3. G_pratik_bhatia_zGkc Cupcake Feb 9, 2017
  4. Ineedone2015 Cupcake Feb 9, 2017
  5. dr.nikhildongre Froyo Feb 9, 2017
    dr.nikhildongre, Feb 9, 2017 :
    Chrome has built in 'web view' in official Nougat update.. Hence there no need of separate 'web view' plugin..
    Sun90 likes this.
  6. G_Vispi_Edibam_bqlo Cupcake Feb 9, 2017
    G_Vispi_Edibam_bqlo, Feb 9, 2017 :
    But paytm transactions do not get completed and error says Android web disabled
  7. Sun90 Starting Point Expert Feb 9, 2017
    Sun90, Feb 9, 2017 :
    Try this and see if it works.
    Go to settings > Developer options and there scroll down to find " Multiprocess web view" it will be disabled by default, Enable the same and reboot the device once and then see, if Paytm works.
  8. F_Pradeep_Yadav_yCGj Cupcake Feb 9, 2017
  9. dr.nikhildongre Froyo Feb 13, 2017
    dr.nikhildongre, Feb 13, 2017 :
    I face no such problem.. Kindly update chrome browser or clear data of it and paytm app once.. Try again for payment thereafter
  10. Mohanraj Sivam Cupcake Feb 18, 2017
  11. delhcf Cupcake Feb 18, 2017
    delhcf, Feb 18, 2017 :
    I also have the same problem - why can i not enable it like all other apps
  12. Mohanraj Sivam Cupcake Feb 18, 2017
  13. delhcf Cupcake Feb 18, 2017
    where is this - couldn't find developer options
  14. Sun90 Starting Point Expert Feb 18, 2017
    Sun90, Feb 18, 2017 :
    That's because since Nougat, it's disabled by default as chrome has its built-in web view implementation.
  15. delhcf Cupcake Feb 18, 2017
  16. Sun90 Starting Point Expert Feb 18, 2017
    Your play store not updating has got nothing to do with this.
    If you are on a roaming mobile network ,u will have this play store issue for now, and it's a known Google issue since Nougat update. Which even the Nexus / pixel users are having for now.
    Mohanraj Sivam likes this.
  17. jayasurya29 Gingerbread Feb 18, 2017
    jayasurya29, Feb 18, 2017 :
    Yes.... Like paytm... Etc.. Have facing problem... But latest update has been released
    . It will solve the issue
  18. Sun90 Starting Point Expert Feb 18, 2017
    Go to settings > about phone. And tap it.
    Then scroll down to Build number and tap multiple times till u see the message " ur a developer now" or something similar.
    Then back to settings u will find it there.
    delhcf likes this.
  19. delhcf Cupcake Feb 18, 2017
    fantastic - your too good - thanks for spending your time and guiding me
    Sun90 likes this.
  20. paul_wigfield Gingerbread Feb 18, 2017
