Raaaj_Kumar , via OnePlus 9 Pro , Jan 21, 2022 : Hi, After updated to c.44 getting too much heat in my op9 pro, please check op team. Thanks
Dresa91 , Jan 21, 2022 : First of all: please stick to the dedicated heating thread! https://forums.oneplus.com/threads/...heating-and-charging-feedback-thread.1412143/ Then the update was released today. Please give the system time to settle after the update
Swejuggalo , Jan 21, 2022 : Give it some time. It takes some time to settle in. It may need a few charge cycles to reach optimal performance. Just check battery stats if you have some errors andmassive drain.
Cervantes , Jan 21, 2022 : Hello there Please, Use the search engine before opening a new thread: Search Check and use the latest update thread for questions and comments, read the first post: Here Check and use the battery thread for battery and heating problems: Here for another user to suggest: upload a screenshot of: battery and other battery uses Install cpuz: check temperature Read the forum rules: Rules Thread closed Best regards, Cervantes, Forum Moderator
