[Answered] OnePlus tv u1s Input Mode
  1. W1530956697784
    Cupcake Jun 25, 2021
    W1530956697784 , Jun 25, 2021 :
    can somebody help me
    I just want to know is there any option to select input without manual control.
    for old people it's hard to select input methode
    if is there any default option then it will be helpful
    device : oneplus u1s tv
    input : av
  2. Tokolozi
    Most Original Avatar Jun 25, 2021
  3. Yash Pratap Singh.
    Lollipop Jun 25, 2021
    Yash Pratap Singh. , Jun 25, 2021 :
    Go to settings > personalisation > Input source memory > turn it on.
    Hope this helps!
    Aarav Sahni and Tokolozi like this.
  4. W1530956697784
    but this will select the recently used input.when j switched to youtube and turn off the tv this won't work😟.
  5. Yash Pratap Singh.
    Currently the TV doesn't have a 'Default Source' selection.
    If you use AV and then turn off the TV, it will open directly at AV when you turn on the TV.
    Aarav Sahni likes this.
  6. W1530956697784
    thanks.i will check and update
    Yash Pratap Singh. likes this.
  7. Yash Pratap Singh.
    Sure...by the way, on a different note
    If you can, then you should connect the STB via HDMI to the TV - its a little better in quality, and if your STB supports CEC, then you can operate your STB via the OnePlus TV U1S remote by enabling HDMI CEC.
    Just a suggestion ✌🏻
  8. W1530956697784
    thanks a lot
  9. #9
  10. Venky61
    OnePlus TV Expert Community Expert Jun 26, 2021
    Venky61 , Jun 26, 2021 :
    There one trick to achieve what you are looking for, obviously it requires your Settop box to be upgraded and also not sure if your STB operator has that feature or not, but you can check.
    Like for example I have Jio Settop box with HDMI CEC and without even this Input Source memory feature, I can use the Jio STB remote to turn the STB On and it automatically turns on the TV too and opens the STB interface instead of Android Home. Unfortunately, there's no clear info on the net about which DTH operators have this feature.
