Any better Kernels than AK Kernel?
  1. geoff78
    Gingerbread Jan 24, 2015
    geoff78 , Jan 24, 2015 :
    Also, picking a governor and i/o scheduler that suits your usage is very important
    #41
  2. malidan
    Nougat Jan 24, 2015
    malidan , Jan 24, 2015 :
    Yes bro very disappointing to see such a fall in benchmarks, is it really a fall in performance or is there benchmark tweeks within the cm kernal. Because funnily enough all my best scores are always with the stock CM kernal no matter which ROM I install.
    #42
  3. tyler539
    Jelly Bean Jan 24, 2015
    tyler539 , Jan 24, 2015 :
    Same here. But I run stock kernel, but if an update ever happens to tank battery life, I will switch to Franco then.
    #43
    Elas likes this.
  4. amoghkulkarni
    Honeycomb Jan 28, 2015
    amoghkulkarni , Jan 28, 2015 :
    Any idea which version goes with CM11s 25R ? I came back to 25R just to give it a try and want to install the AK Kernel. Already tried AK-072 for CM11s and it gave me a bootloop.
    @netr0pa Tagging you as you are the face of 25R ;) can you help me here?
    #44
  5. netr0pa
    Jelly Bean Jan 28, 2015
    netr0pa , Jan 28, 2015 :
    To be honest, I have never understood the need of custom kernel on 25R....
    You don't even need to cheat with custom kernel when you are running 25R to be honest...
    But to each his own. If you like to experiment with your phone, then go ahead but I stay strong with the stock kernel which gave me 12 hours SOT so for me, no need for AK 47 kalashnikov -kernel or Franco kernel or what ever other kernels there are out there.
    "If it doesn't break, no need for change", that's my motto.
    #45
  6. divinityQQ
    divinityQQ , Jan 28, 2015 :
    It depends on what you value the most. If you want to have ultimate battery time, then 25R is probably the right choice, even though I have never been running it. If you prefer best performance and smoothness, then don't lose time and flash away CM12. Flashing kernel is optional, right now I'm running AK 097 and I can't be happier. Not a single lag and loading times are just awesome, and when im talking about no lags, i really mean 0.
    #46
  7. TheJames
    Jelly Bean Mar 4, 2015
    #47
  8. chvzed
    Ice Cream Sandwich Mar 4, 2015
    #48
    PrashantRev likes this.
  9. xoqes88
    xoqes88 , Mar 4, 2015 :
    Tried AK kernel and Franco. From my experience, AK is for those hardcore tweakers (with AK and the Synapse app you can tweak anything) so I ended up using the Franco Kernel. I have great battery life (I am also using Greenify) and I just let the kernel do everything by itself.
    #49
  10. FXA
    FXA , Mar 4, 2015 :
    I prefer Franco. The battery life is better than with AK Kernel and Franco has more screen color options.
    #50
    JelleZon and PrashantRev like this.
  11. dat niggah
    Honeycomb Mar 4, 2015
    dat niggah , Mar 4, 2015 :
    I don't want to tweak much with kernels too. BTW which Android version are you running? I am running euphoria rom on my OPO. it is stable but drains MORE battery in standby mode. like 35% in one night....
    #51
  12. xoqes88
    If it drains 35% something is not right. You have apps running on the background or even a rogue app. Use Wakelock detector to see what it is.
    I'm using the last CM12 nightly. Normally overnight it drains between 3 and 6% which is pretty normal.
    #52
  13. JelleZon
    OnePlus Accessory Tester Mar 4, 2015
    JelleZon , Mar 4, 2015 :
    Try to uninstall the play services
    #53
  14. dat niggah
    It's nothing related to play services. It only takes 2% battery. There's a problem in the ROM itself I guess...
    #54
  15. JelleZon
    Android OS takes the most % oft battery? Then its caused by the play services!
    #55
  16. forid-786
    forid-786 , Mar 4, 2015 :
    Franco is pretty much the best right now I'm my opinion. Boeffla sucks on Oneplus one, and is no where near as good as it was on my S3. AK, to me is worse than stock.
    #56
  17. dat niggah
    Android OS takes 1% LOL. it's a bug actually in 5.0 ROMS, that it keeps on running google+ and some apps in the background. It would be fixed in the next 5.1 by google. Lollipop is Gonna ROCK.
    #57
  18. dat niggah
    C'mon! how can AK prove poor on the OPO (Tho, haven't tried)
    #58
  19. agodo
    Ice Cream Sandwich Oct 2, 2015
    agodo , Oct 2, 2015 :
    anyone has some profiles for synapse running ak kernel on the oneplus 2???
    #59
