Any Way to use 4g network in both sim 1 and sim 2 at Same time?
  1. Bhupender Rana
    Cupcake Jul 7, 2018
    Bhupender Rana , Jul 7, 2018 :
    like other smartphones like Samsung s9 plus we can use LTE in both the sims at the same time. Is there any way or update to use this feature on OP5T?
  2. Nezumi_
    KitKat Jul 7, 2018
    Nezumi_ , Jul 7, 2018 :
    nope, not possible.
    gotshoaib, the_o2 and MentalDraco like this.
  3. Bhupender Rana
    Cupcake Jul 7, 2018
    gotshoaib likes this.
  4. Nezumi_
    KitKat Jul 7, 2018
    no, it won't be supported cause the sd835 chip doesn't have dual sim dual volte technology.
  5. GokuUltraInstincts
    Jelly Bean Jul 7, 2018
  6. Bhupender Rana
    Cupcake Jul 7, 2018
    different banking accounts linked with different numbers so missing important updates
  7. Am4nk
    Gingerbread Jul 7, 2018
    Am4nk , Jul 7, 2018 :
    That shouldn't be affected by one 4g turned off, bank accounts need internet once logged in/ started. They don't need internet from the specific mobile number registered. even wifi works. I don't know what made you think that. I have dual sim, different accounts linked to different numbers and I use 4g on only one sim. works for me. never missed an update. even on wifi when mobile data is turned off. it might be the bank setver issues that are being delayed.
  8. Bhupender Rana
    Cupcake Jul 7, 2018
    I have two jio sims inserted in each port and I get network in only one sim other is turned off by default as its a 4g sim
  9. Am4nk
    what are you talking about? you can use both the sims at the same time in 4g. I think that's jio's problem because it doesn't let you use 4g if inserted in the 2nd sim slot. nothing op can do in that. use a better network than jio. God! I've seen people use jio for internet as a sim, but having both jio is just useless in my opinion.
  10. Bhupender Rana
    Cupcake Jul 7, 2018
    I think you are right, I should port my number to other network
    Am4nk likes this.
  11. F_Craig_Jones_ZQdy
    F_Craig_Jones_ZQdy , Jul 7, 2018 :
    I have a 2 Sims both 4 and sim2 works on 4G fine.
  12. Am4nk
    I know. But the network operator 'JIO' in india doesn't let you use 4g if inserted in the 2nd sim slot. heck, it doesn't even sometimes give signal reception. It compulsorily needs Master Sim Slot. It's a pain in the bum, I don't know why it was implemented in the first place.
  13. F_Craig_Jones_ZQdy
    never knew this. lean something new each day
  14. Nezumi_
    KitKat Jul 7, 2018
    correction: jio is 4g only network, that means it doesn't have 3g or even 2g networks for backwards compatibility and every time sim 1 slot is used for the network the second sim slot will be switched to 3g network to save battery, that's why jio sim won't work on the second slot assuming you're using the first slot for network.
    Am4nk likes this.
