14
anybody need help to get 8 hour plus sot?
  1. F_Junaid_Khan_kKSE
    Honeycomb Apr 2, 2017
    F_Junaid_Khan_kKSE , Apr 2, 2017 :
    tmp_15632-Screenshot_20170405-0252381038541654.png tmp_15632-Screenshot_20170405-0310031794182653.png
    This thread can help you increase your battery performance as you might be having battery draining issues with less stand by time or heating problems.
    You have to go through the discussion here as you might find a solution to your scenario.
    I've had such issues as well and spent some good amount of time figuring a few things out. In short there is some problem with phones who are updating from a previous version without a clean install..
    Things are fixed now and for most of the people it is working out other people still stuck can always ask a question.
  2. F_Junaid_Khan_kKSE
  3. Android450
    Marshmallow Apr 2, 2017
  4. SahilQureshi
  5. richard_le
    Donut Apr 2, 2017
  6. G_Billybob_Schneider_lnm
    Froyo Apr 2, 2017
  7. G_Billybob_Schneider_lnm
    Froyo Apr 2, 2017
  8. Andriod_Central
    Cupcake Apr 2, 2017
  9. F_Junaid_Khan_kKSE
    you have to give your phone some time to fine tune it according to your usage..
    first of all turn off aggressive doze and just leave normal doze on from developers menu... now if you are on data than turn off background data for all apps you don't use and also force close if you know what you're doing ... than turn off back up data and nfc stuff - also most important your phone is awake even after screen off is Google play services..
    for that you should first check your activity controls on your gmail account.. and turn off everything you don't need Google to know about you.. than also turn off usage access of everything from the apps menu ..
    guaranteed 7 hour plus even with all the social apps and gaming ..it's a great phone we need to set it according to our usage..
  10. F_Junaid_Khan_kKSE
    F_Azeem_Ahmed_dPmp likes this.
  11. F_Junaid_Khan_kKSE
  12. F_Junaid_Khan_kKSE
  13. F_Junaid_Khan_kKSE
    G_Julius_Verne_JnoR likes this.
  14. F_Junaid_Khan_kKSE
  15. Android450
    Android450 , Apr 2, 2017 :
    I don't understand the Gmail part?
  16. F_Junaid_Khan_kKSE
    Adarsh_das likes this.
  17. Android450
    Use the web interface
    G_Rajun_Doal_Ieis likes this.
  18. akash2k13
    Cupcake Apr 2, 2017
    akash2k13 , Apr 2, 2017 :
    Junaid hw do we tweak the google service thing? dint undstd it well, and also cudnt find whr to restrict background data app.. can u please suggest? thanks!
  19. F_Junaid_Khan_kKSE
    settings .. personal .. Google ... personal info and privacy .. scroll down to find manage activity controls ... there you need to explore a little.. as Google is uploading a lot of data of your usage all the time like location web history and other stuff.. so turn it off.. also turn off the nearby service under the same menu. where it's constantly searching the areas.. so basically if your typical day involves traveling than you really need to look into these settings, as they're constantly eating your battery for no benefit to you as you go about your day
    J_Alarcon, RubenMaia and Corespeeder like this.
  20. F_Junaid_Khan_kKSE
    please read my last reply - it's pain I know but you have to really explore the settings under the Google tab
