Anyone facing battery issues with one plus bud z via OnePlus 9 Pro
  1. X1562626681582
    Cupcake Apr 11, 2021
    X1562626681582 , via OnePlus 9 Pro , Apr 11, 2021 :
    My right ear buds subscribed shows 1 percent battery and keeps flickering to 100 % and 1% . Like one second it'll sure 1% battery and the very next second it'll be 100 again and then this keeps happening on a loop until i close the charging case and then open it again
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Apr 12, 2021
    Dresa91 , Apr 12, 2021 :
    Did you reset the buds?
    If yes and the issue still occurs, please contact support.
  3. adi.muhic
    Froyo Apr 12, 2021
    adi.muhic , Apr 12, 2021 :
    I have some major issues with case, and charging of it. It seem I got the faulty one, because it's impossible to fully charge the battery case. Even when it sometimes shows it's 100% charged, just after hour or two when I connect the buds and case via bluetooth, battery on the case is around 50%. And that happens even when I don't use buds so they are fully charged. Recently I noticed that red indicator on the case turns green just few minutes on charger. But when I unplug it from charger and plug it again, it turns red again so it means that the case is showing it's fully charged by mistake.
  4. X1562626681582
    Cupcake Apr 15, 2021
  5. Dresa91
    User of the Year 2016; Most Active User 2020 Apr 15, 2021
  6. X1562626681582
  7. Dresa91
    Dresa91 , Apr 15, 2021 :
    Then please contact support
