Anyone having massive heat, no apps running, not charging, no games? via OnePlus 8T
  1. Nomad69
    Cupcake May 14, 2021
    Nomad69 , via OnePlus 8T , May 14, 2021 :
    My CPU on my 8t is running at 55 degrees Celsius with no apps running. It's usually just surfing the net or reading the Google feed. I have no social media apps, no games, and am not charging. I first noticed it because the phone gets really hot to the touch especially at the upper part opposite the camera so I downloaded an app to check the internal temps. Everything online says 45 Celsius is the max but mine never gets below that amount (ever). Am I alone or any suggestions?
  2. Starcommander
    OnePlus Accessory Tester May 14, 2021
    Starcommander , May 14, 2021 :
    Disable OnePlus cloud
  3. Nomad69
    Thanks, I don't think I have OnePlus cloud, I'm on the USA variant (non Tmo) and I don't see that as an option anywhere but I could disable Google backup and see if that's causing the issue.
    Starcommander likes this.
  4. Starcommander
    Oh well, I had same issue and mine was Indian variant. Disabling the cloud fixed the issue for me. May be your phone is backing stuff to some cloud while you are not using it..
    Nomad69 likes this.
