AOD does not dim like it should.
  1. Vkingoff
    Eclair Jan 23, 2021
    Vkingoff , Jan 23, 2021 :
    Oneplus 8T
    Hello, I need an official technical answer from Oneplus. Maybe, you can fix such a bug in the next update. AOD was working fine in 11.0.5.6 but now in 11.0.6.8 the next thing is broken. Previously aod was dimming when set to always and the phone is in a dark place but for now the brightness of AOD set to always is constant and do not change! Please, fix that behaviour to make it work like in 11.0.5.6. AOD should dim and should be dark in a dark room) It is only when it's set to always or scheduled. If it is activated only on touch or lift up ambient dispaly dims like it should.
    Wait for your answer and feedback.
    It happens for AA, BA and DA
  2. ShreyasPatil_
    Ice Cream Sandwich Jan 23, 2021
  3. Dresa91
    User of the Year 2016; Most Active User 2020 Jan 23, 2021
    Dresa91 , Jan 23, 2021 :
    Did you clear cache via recovery and turn AOD off and on?
  4. Vkingoff
    Eclair Jan 23, 2021
    Vkingoff , via OnePlus 8T , Jan 23, 2021 :
    I have done everything with full wipes, nothing helps...
  5. Dresa91
    How about a factory reset?
  6. Vkingoff
    Eclair Jan 23, 2021
    Tried. Do not work.
    Now I get back to 11.0.5.6 via msm tool and waiting)
  7. Vkingoff
    Eclair Jan 23, 2021
  8. Vkingoff
    Eclair Jan 23, 2021
  9. Dresa91
  10. Dresa91
    I am using a Pixel 3 :D
  11. Vkingoff
    Eclair Jan 23, 2021
    Dresa91 likes this.
  12. Dresa91
    Okay, good luck:)
  13. eastbay
    KitKat Jan 23, 2021
    eastbay , via OnePlus 8T T-Mobile , Jan 23, 2021 :
    In the ambient display section I have three options how I want to see my aod. But there's no brightness setting. It's not very bright. I called tech and that's what they Said. This is to avoid screen burn!!! 👊🏻
  14. Vkingoff
    Eclair Jan 23, 2021
    I mean that mine is too bright. Yes, i have Off, Schedule and Always. When i enable Schedule or Always than on 11.0.6.8 after turning screen off AOD is enabled. And its brightness stay at the same pretty bright level. Previously on 11.0.5.6 AOD was staying bright only for some seconds and after that it dimmed, get darker.
    Maybe, you can call them and tell about this bug...(
    I want to avoid screen burn, i want more battery life because of it AOD should work like it did and became darker)
  15. StefanStark
    Ice Cream Sandwich Jan 24, 2021
    StefanStark , via OnePlus 8T Aquamarine Green , Jan 24, 2021 :
    Have you tried it in a dark environment?
    AOD setup page says it dims in dark environment to save battery.
    Have you unplugged the phone?
    There is a setting to keep AOD always visible while charging or in the dock so people use it as watch / weatherstation / calendar on the nightstand.
    eastbay likes this.
  16. #16
    eastbay likes this.
  17. Vkingoff
    Eclair Jan 24, 2021
  18. Vkingoff
    Eclair Jan 24, 2021
    Vkingoff , via OnePlus 8T , Jan 24, 2021 :
    Yeah, tried in dark. Now I installed 11.0.5.6 and it dims in dark like it should. Seems that it is firmware 11.0.6.8 related problem. Hope so much that they will fix in the next update [e]1f64f[/e]
    eastbay likes this.
  19. eastbay
    KitKat Jan 24, 2021
  20. eastbay
    KitKat Jan 24, 2021
    eastbay , via OnePlus 8T T-Mobile , Jan 24, 2021 :
    Can you swap out on warranty??
