6
APN Problem N10 5G
  1. drl431
    Community Hero 2020 Jan 18, 2021
    drl431 , Jan 18, 2021 :
    If that was true OnePlus would have to do weekly updates to keep up to date with every network provider on the planet.
    Caoimhín and jamesmack like this.
  2. iamWarder
    Froyo Jan 18, 2021
    iamWarder , Jan 18, 2021 :
    Can confirm, that placing a Telus Sim in other One Plus phones works fine with no issues. It only does not work with the Nord N10
    Have also tried it with mutiple Telus Sims. Where it only just doesn't work for the Nord N10, works on Op1, Op5 and SS S20s
    jamesmack likes this.
  3. jamesmack
    Eclair Jan 18, 2021
    jamesmack , via OnePlus Nord N10 5G , Jan 18, 2021 :
    This would be true.. but only when the manufacturer locks the APN setting or a bug keeps the end user from adding or editing the APN. said:
    "This is how android handles APNs. There is a file called apns-conf.xml that resides in the system partition containing the available APNs that the OS can choose from. Depending on the SIM card that is inserted into the phone, the OS will try to pull from the file what is believe to be possible matches. Some OEMs do not provide a full set of APNs and as a result, the user is then required to manually enter one."
  4. drl431
    If that is what you choose to believe, then you only have one choice...
  5. jamesmack
    Eclair Jan 18, 2021
  6. jamesmack
    Eclair Jan 18, 2021
    Update from OnePlus:
    "In order to check this further, we would need device updated logs and screenshots at the time of issue occurrence. Be assured that your data would be safe and secure.
    1. Which Carrier / Service Provider you are using?
    2. The Type of Network (VOLTE/4G/3G) used?
    3. Is the SIM working on other phone?
    4. Is other SIM working on this Phone?
    5. APN Information :
    Logs Capture procedure:
    1. Input *#800# from dialing interface to enter " OnePlus Logkit", click the [Delete icon] in the upper right corner to delete the historical log.
    2. Click “Basic Log” in the setting bar to enter the setting interface, click “Log save location”, select “/sdcard/oem_log”, and then select “get bugreport when stop logging”, click “Enter”, so the log path is at the sdcard location.
    3. Back to the main interface of the OnePlus Logkit, click the “Advanced” button in the bottom navigation bar, and open the “Copy Screenshot” switch.
    4. Click “QXDM Log” in the setting bar to enter the setting interface, click “QXDM Log type”, select “Modem-Common”.
    5. Back to the main interface of the OnePlus Logkit, click “QXDM Log” bar "Play" button to save logs, when it informs you whether to reboot, click “NOT REBOOT”
    (Important) Reproduce the issue and take 1 or 2 screenshots to record the issue happening time.
    6. After Reproduce the issue then Enter *#800# on dial pad to enter “OnePlus Logkit”, click the “Tools” button in the bottom navigation bar, choose “other log info”, click “get bug report info” just before you finish the log process (it takes several minutes, wait till it’s done)
    7. Back to the main interface of the OnePlus Logkit, and then click “QXDM Log” bar "Play" button to stop it
    8. Enter file manager, choose storage, find the oem_log file and long press and click right upper corner three dots to compress it and update it in Google drive along with the screenshots.
    Note:
    1. Please log into Google drive and select the file and there will be an option to share.
    2. Log into Community through web browser and the option to paste the drive link will be available where you have received this message.
    3. After you share us the logs, please delete the file from your phone or it will occupy a lot of storage."
  7. Z1608612891168
    Cupcake Jan 18, 2021
    Z1608612891168 , Jan 18, 2021 :
    Hi folks;
    same issue on my device (Nord N10 5G) as well. I am on Telus network as well. Shaw SIM works but no Data connectivity to Telus. Cant alter APN. Default apn is set to isp.telus.com. Which does not work. Performed factory reset, system upgrades, etc. Telus support advised to change SIM card. Heading off to a store.
    Thanks
  8. ggenglish
    ggenglish , Jan 18, 2021 :
    Same issue here. Big thanks to everyone above that has pushed this forward. I guess we have to wait for it to reach the proper department and they have their 'oh s***' moment.
  9. Z1608612891168
    Is there a way to escalate it to Oneplus. Or at least have them use team meeting etc. and access my phone to update that apn xml config file.
  10. jamesmack
    Eclair Jan 18, 2021
    B1615349511256 likes this.
  11. Cervantes
    Moderator Moderator Jan 18, 2021
    Cervantes , Jan 18, 2021 :
    Hi
    One Plus support page: Here
    if it is a software problem: Submit Bug: Here
  12. iamWarder
    Froyo Jan 18, 2021
    Bug already submitted, Support has been escalated by a few already.
    drep4521 and jamesmack like this.
  13. Z1608612891168
    Thanks guys!
  14. scrawl
    Froyo Jan 19, 2021
    scrawl , Jan 19, 2021 :
    Just to add my experience, I spent about 80 minutes on the line with Telus support and OnePlus support this evening, both at the same time. OnePlus support figures I should get a new SIM card (even though it works with my geriatric OnePlus 2), Telus figures it's a phone software problem. Consensus here suggests it's more likely the latter than the former, so I'm not going to shrug on the hazmat suit to find a new SIM.
    And yes, I've tried all the things on my phone, including a factory reset (which was little more than a token effort, considering the N10 arrived eight hours ago).
  15. KinseySS
    Cupcake Jan 19, 2021
    KinseySS , Jan 19, 2021 :
    same issue here, OnePlus said I need a new SIM card yet when I go to my APN settings on my OnePlus 2 not only is there 5 different APN settings I can choose from on the same SIM, I can edit it too.
  16. iamWarder
    Froyo Jan 19, 2021
    iamWarder , Jan 19, 2021 :
    Correct, I talked with online Telus, and they suggested its not the SIM card, like they normally would. I also made an appointment to go into Telus and get a new SIM. They tried three, none of which worked. Their "tech savvy" person said that is likely a setting in the phone that needs to change in order to edit.
    Went around the mall, and asked the other phone kiosk's (only things open in the mall lol) and tried the other carriers, worked on them all except Telus.
    There is clearly an issue between OP and Telus.
  17. jamesmack
    Eclair Jan 19, 2021
    jamesmack , via OnePlus Nord N10 5G , Jan 19, 2021 :
    OnePlus: "We have made a note of this and our developer team is currently working on this. We will keep you posted regarding the further updates. We appreciate your support and patience in this regard."
  18. jamesmack
    Eclair Jan 19, 2021
    An update from MobileSyrup:
    "OnePlus got back to me with this image today explaining how to try and fix the problem and a notice saying their gonna push out an update in early feb to correct it. Hopefully, this can help!"
    1611074442098.jpg said:
    Doesn't work for me as there is no + sign. And even with the sim card trick, the APN does not save.
    Can everyone else confirm?
    #38
    J1612485263524 and ggenglish like this.
  19. ggenglish
    ggenglish , Jan 19, 2021 :
    THANK YOU jamesmack. I can confirm this works. Indeed there is no + sign but if you popout your simcard while in 'SIM & network settings' the whole area will be disabled. Then push your tray back in and as soon as it's available select 'access point names'. You should see a + sign before the phone has time to decide to disable it.
    #39
    J1612485263524 and scrawl like this.
  20. jamesmack
    Eclair Jan 19, 2021
    Glad it worked for you! Could you share a little more.. what build are you on? Step by step process?
    #40
